20 Most Recent
Blade 3 5/8 Inch Jig Saw Questions & Answers
Replacement part for Deni model 14300 food slicer
You may be able to find a replacement blade holder for the Deni model 14300 food slicer by contacting the manufacturer directly or by checking online retailers that specialize in replacement parts for kitchen appliances. Some potential sources to check include Amazon, eBay, and the manufacturer's website. Be sure to have the model number and any other relevant information about the part you need on hand to ensure that you find the correct replacement.
2/24/2023 10:25:23 PM •
Blade Saws
Answered
on Feb 24, 2023
Kobalt 24v brushless reciprocating saw seizes when you pull trigger. It clicks (light comes on) but blade won't move
It sounds like you are experiencing an issue with your Kobalt 24v brushless reciprocating saw. There could be a few potential causes for the saw to seize when the trigger is pulled and the blade won't move. Here are a few things you can try:
- Check the battery: Make sure that the battery is fully charged and properly installed in the saw. If the battery is low or not seated correctly, the saw may not have enough power to operate.
- Check the blade: Make sure that the blade is properly installed and tightened. If the blade is not properly installed or tightened, it may cause the saw to seize.
- Check the motor: If the motor is not functioning properly, it could cause the saw to seize. You may need to have the motor checked by a professional if this is the case.
- Check for debris: If there is debris stuck in the blade or in the saw, it could cause the saw to seize. Carefully remove any debris that you find.
If these troubleshooting steps do not resolve the issue, it may be necessary to take the saw to a repair shop or contact the manufacturer for further assistance.
12/27/2022 4:13:28 PM •
Blade Saws
Answered
on Dec 27, 2022
