20 Most Recent
Uniden TRU8885-2 Cordless Phone Questions & Answers
De-register broken handset
We thank you for being a loyal customer. Please note this model has been discontinued for more than 2 years and unfortunately, troubleshooting and/or parts are no longer available. We apologize for any inconvenience this may cause you.
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide
E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
New handset
http://www.amazon.com/Uniden-TRU8885-2-Cordless-Handsets-Answering/sim/B0001F9KLY/2
I have a Uniden TRU8885
buy higher capacity power adapter 9volts 1000mA capacity and use ensuring correct polarity, it will work. i had the problem and adopted this and this works ok. also ensure your handset battery is new and charged after installing the higher capacity power adapter. good luck. venkataramani
TRU9480
deresister hand set completely by pressing and holding end Key and # key for at least 30 sec or till you get massage on hand set screen that hand set is deregistered compleately
How do I mute the
To mute the ringer, while in standby mode press the volume-down button to select Off.
To mute the microphone, while talking press the MUTE softkey.
To put the phone into do-not-disturb mode, press and hold the do not disturb button on the base.
You can download the manual from the manufacturer's web site at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU8885om.pdf
Uniden Tru8885-2
The older Tru8885 phones will not work with the new base unit. My recommendation would be to ebay those and then buy new ones or find replacements for your new base on ebay also.
De-register/register
To De-register handset while original base present:
-Use De-register menu
To De-register handset without original base present:
-Press and hold "End" button, and while holding that, press and hold # as well.
OR
-Remove battery
-While holding * and # replace battery, and keep holding
-You should hear one beep (let go now)
-Press right menu soft button (at top)
-Should hear one beep and Clear EEPROM/RAM on screen
-Remove and replace battery once again (no need to hold any buttons now)
(USING ANY OF THE TWO METHODS ABOVE MEANT FOR NON-BASE PRESENT, WHILE BASE IS PRESENT WILL TAKE UP HANDSET SPACE ON BASE, eg. HS1 will become HS2, while base reserves HS1 name... a base reset will be required to deal with this).
Resetting the base itself (if you have any handsets deregister them normally before this)
-Unplug power
-Hold 'Delete Messages' key while plugging power back until beep (88 or 0 messages may show)
-Press PLAY once
(To check that all went well, check to see if anything shows under ROOM MONITOR, nothing should be there)
