Pres remote starter Model APS-901, the remote will
PLEASE READ THE ENTIRE POST BEFORE BEGINNING
There are several reasons that could cause the remote starter to shutdown immediately after it starts:
1. It may be the lack of a tachometer signal. Did you hook up the green/orange wire to a uncommon wire at a coil or fuel injector? If not, did you program the remote starter for tachless? If you didn't hook up the tach wire, no problem; let's program the remote starter for tachless:
Turn ignition on, press and release programming switch three times. The parking lights will flash one time. Turn key off, then on, then off, then on. You are now in bank three (remote starter programming). Press and release the programming button five times. The parking lights will flash the number of the times for the setting for this feature. If you have not attempted to progarm the unit, it will flash two times (default setting is for TACH). Press and release the start button on the remote once, it will flash three times; press and release the start button again, it will flash once. The unit is now programmed for voltage. Turn the key off. If you have not attempted to do any programming on the unit, the default setting for crank averaging is AVERAGING. This means that you will have to start the vehicle at least four times with the key to be effective. Test the system.
If the problem still exists, let's try this:
2. If you did not hook up the tach wire and you already had the unit programmed for voltage and, the remote starter shuts down (probably when the parking lights come on); the 901 is seeing a drop in voltage and you need to hook up the tach wire. Connect the green/orange wire to an uncommon wire at a fuel injector or coil. An uncommon wire is one that is a different color, at the same pin location, on each coil or injector. For example; compare two fuel injectors: if they are two pin connectors you may see an orange and a pink. At the next injector you may see an orange and a blue. The orange is the common wire and the pink and the blue are uncommon wires. You may connect the green/orange to either one of the uncommon wires. After the wire is connected, turn the ignition on, press and release the programming button three times. The parking kights flash once. Turn the key off. Press and HOLD the programming button, start the vehicle. The parking lights will begin to flash, continue to hold programming button for approximately 15 second. Release the programming button, the parking lights will come on then, go off. The tach is now programmed. Turn vehicle off. Refer to the above section for remote starter programming features in bank three. Test system.
Remember: If you did hook up the tach wire there is no need to program the 901 for tach. Tach is the default setting.
3. If the remote starter still continues to shut down, the problem may be with your need for an immobilizer bypass. You failed to mention the year/make/model of the vehicle so, try inserting the key into the ignition then, remote start the vehicle. If the vehicle starts and runs, you will need to bypass the "chip" in the key for the remote starter to function as desired.
