20 Most Recent Audiovox Prestige Code Alarm Remote Alarm Protx6 Questions & Answers
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Audiovox... | Answered on Dec 08, 2017
i would think the button is activating the fob, or when you put new battery in is it the right way or you may have pushed something inside and its come lose off the board, it would need opening up and having a look, and testing the switch.
Audiovox... | Answered on Jun 10, 2017
I would either go to the website for the manufacturer of the keyfob and search the troubleshooting section or get the company phone number and call them and get instructions for the programming codes. good luck.
Audiovox... | Answered on Apr 21, 2014
Provided that your system is not programmed for coded override, the standard emergency override is as follows:
1. Enter the vehicle (the security system will trigger.)
2. Locate but do not press the valet/override switch yet (it should be a small black button installed under the dash within reach of the driver)
3. Turn the ignition key to the ON position.
4. Press and release the emergency override button (The security system will turn off).
Note: If the automatic arming feature is enabled on your system. The security system will re-arm the next time the ignition key is turn off and the vehicle's doors are closed.
If the coded override feature was enabled by the installing dealer, you will need to follow these procedure:
1. Enter the vehicle (the security system will trigger).
3. Turn the ignition switch to the ON position.
4. Within 5 seconds press the emergency override button the number of times corresponding to the first digit of your personal code (Default digit is 1).
5. Within 5 seconds turn the ignition key OFF, then ON.
6. Within 5 seconds press the emergency override button the number of times corresponding to the second digit of your personal code (Default digit is 1).
7. Within 5 seconds turn the ignition key OFF, then ON.
8. If entered correctly the security system will turn off.
9. Turn the ignition key to the OFF position.
If the coded override feature is enabled and the code is lost, the system will need to be reprogrammed by an authorized dealer.
Audiovox... | Answered on Jan 08, 2014
Replace BCM, (body control module).
Audiovox... | Answered on Oct 28, 2013
Need to know how to wire the door locks on 5 wire reverse polarity vehicle
Audiovox... | Answered on Feb 01, 2012
Audiovox Prestige Code Alarm Remote Alarm Protx6 Logo
59 questions posted
Top Prestige Appliances Vehicle Parts & Accessories Experts
xxxxxx xxx
Rocguy
Tim Marx
Tim Marx
Are you a Prestige Appliances Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Prestige Appliances Vehicle Parts & Accessories
Most Popular Question
code alarm car remote dont work
  • Vehicle Parts & Accessories
