FixYa.com
Fein 9-88-35 Canister Wet/Dry Vacuum
All Products > Fein > Vacuums
Problems with Fein 9-88-35 Canister Wet/Dry Vacuum?
Search inside Fein 9-88-35 Canister Wet/Dry Vacuum Knowledgebase
Troubleshooting and Support
Solved Problems for Fein 9-88-35 Canister Wet/Dry Vacuum RSS Feed Post a New Problem
How can i Replace a drive belt of my...
How can i Replace a drive belt of my vacuum?
1 Solution
I have a feeling the original problem was...
I have a feeling the original problem was a result of vacuuming up dog hair (I have 2 huskies), but I always kept the...
1 Solution
Unable to Extract Water
I am able to shampoo but the unit is not extracting the water from the carpet.
1 Solution
changing the belt
I have an old dirt devil(model#5200)I think the belt might be broken but I can't get the bottom off, whats the secret?
1 Solution
i cant get the roller back in place
please help i have a kirby that i cant get the roller back on after taking off and putting on a new belt! it is driving...
1 Solution
Eureka Central Vac-Sweeper -Model B1501
There is something clogged in the sweeper (not the hose) of our Eureka (The Boss) vacumn. How do I get in there to clean...
3 Solutions
Kirby G6 Shampooer
I need instructions as to how to put the shampooer together and if there is a way to make it compact enough to do...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Feature
DesignCanister
Dirt CaptureWet/Dry
Tank / Bag Capacity18 Gallons
Motor
Consumed Power1200 Watt
Amperage19 Amp.
Motor Stages2
Suction
Waterlift99 in.
Airflow126 cfm
Filtration
Filtration TechnologyHEPA
Tools
Number of Tools6
Convenience
Cord reach16 ft.
Hose Reach10 ft.
Special Features
Filtration Efficiency5 µ
Sound Level57.8 dB(A)
Weight
Weight44 lb.
Fein Contact Information
Main support number1-800-441-9878
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
