20 Most Recent Juki TL2000Qi Sewing & Quilting Machine TL-2000Qi, 6x9" Arm Space, Extension Table, Drop Feed, Knee Lever 1/2" Foot Lift, Walking Foot, 6 Feet TL98Q Questions & Answers
Several common problems that cause skipped stitches:
1. the needle has either a burr or a flat point/change your needle.
2. Make sure your needle is in the machine straight. If the eye of the needle is crooked, it puts too much tension on the thread.
3. Sometimes the material isn't being held tightly enough between the foot and the machine and the material is moving up and down (flagging) with the needle. If your material is very soft, you can add a piece of tear away backing or try to stretch the material tighter before you start quilting.
4. If you have broken a needle in the past (which of us hasn't broken a needle!?!?!) there may be one or several nicks out of the cover plate hole (where the needle goes down into the machine with each stitch). Take your plate out and examine it in a good light and see if the edge of the hole is smooth. If not, you can either replace the plate or if you can find a piece of emory cord, you can use it to buff the divots away.
5. If all else fails, you might try to use a larger size needle or change to a different type of thread. It also helps to have the same type of thread in the top and on the bobbin.
Good Luck
Juki TL2000Qi... | Answered on Jun 03, 2016
Janice, Return for exchange or refund, faulty machine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Juki TL2000Qi... | Answered on Apr 09, 2016
I believe that you have thread trimming on this machine. I have an older model. If your blades are hung up, you won't be able to turn the hand wheel forward .Unplug your foot pedal and look underneath to see if your blade is hung up and blocking the needle. I think there is a default that keeps your machine from sewing when the blade is in the way. I will need to look again but I think it is similar to an industrial Juki and has two blades: a stationary blade and a moving blade. If a glob of thread was caught in the blades or something, it can throw the setting of them off or actually break a piece of the blade off. If this appears to be the problem, a mechanic is probably your best bet.
Juki TL2000Qi... | Answered on Mar 07, 2016
thread skipping (that's what its called) is most of the times caused by Not the bobbin but the main thread tension being too tight , as it goes thru to get a wrap on bobbin thread its too tight to make a loop large enough for the shuttle to grasp a loop and pull it tight , this tension needs to be changed 4 every change in texture or thickness of fabric as rarely its one setting takes all
Juki TL2000Qi... | Answered on Feb 05, 2016
I did a series of photos of threading my 655 a couple of years ago; I bet when you rethread the red position (lower looper), you forgot to unthread the needle eyes first. When you've finished with the red thread, rethread the needles. If you don't, you get caught in the endless cycle of rethreading/breaking/threading.
You might want to join the yahoo groups "sergers" and/or "creativemachine" -- both very helpful with questions like these, and others.
Juki Furniture | Answered on May 22, 2014
Furniture is the spirit of your residence. It reflects your personality and your way of life. So its necessary to do some research before coming to any conclusion. Over the web, you'll get an entire scope of Furniture Designs and Home D?cor articles to breathe life into your brick-mortar house.
I'm here to refer you a solitary place named "ESF Wholesale Furniture" who take the pride ourselves on partnering with the best furniture manufacturers worldwide to bring our customers a thoughtful selection across all product categories and price ranges. We offer you an ideal mix of classic and contemporary furniture to give your home a vintage modern look. To know more about ESF Wholesale Furniture services get visit here:
Wholesale European Furniture ESF Wholesale Furniture
Furniture | Answered Yesterday
Try Googling (Sharper Image)(HTT-10CRPV)(manual) without parens.
Fixya is unable to suggest sources for replacement chair arms.
Furniture | Answered 2 days ago
Request assembly instructions directly from Ashley.
Yes, online poker is a better option.
You can play online poker in any of the device you are having with you.
Some of the advantages of playing poker online are:
a. Convenient
b. Welcome bonus
c. No time limit
d. Disturbance free
e. Wide range of options, etc.
If you also want to play online Poker, you can visit the link provided here.
Furniture | Answered on Mar 13, 2018
Try Googling (brand)(HVTSM18DA88)(manual) without parens.
Juki TL2000Qi Sewing & Quilting Machine TL-2000Qi, 6x9" Arm Space, Extension Table, Drop Feed, Knee Lever 1/2" Foot Lift, Walking Foot, 6 Feet TL98Q Logo
11 questions posted
Top Juki Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Juki Furniture Expert? Answer questions, earn points and help others
View Most Popular
Juki Furniture
  • Juki Furniture
Most Popular Question
when free motion quilting skipping
  • Furniture
