20 Most Recent
Electronic Arts The Lord of the Rings Conquest for Xbox 360 Questions & Answers
Lord of the Rings: Conquest for PC error
Check your screen resolution. The optimum settings should be listed in your guide book.
Also, check the graphics settings required for the game compaired to the graphics card in your computer; you may need to upgrade.
Good luck and please rate my solution accordingly.
V/r,
Don
I cannot connect to EA
it has nothing to do with friends or anything.EA closed their servers due to insufficient players.Even though there are a huge fan base and hundreds could be playing, they still have them closed.
Cant connect to ea server
EA took the servers offline.........sorry to be the bearer of bad news. There are a few free programs out there that you can use to get online through a host server. One taht i have usex is xlankai
Playing online
Are you perhaps using a wireless connection? depending on which system of connection you are using may determine how well of a connection between you and said games servers.
This may also include certain games that have been known to have weak server connections making it ahrd for online gameplay.
Lord of the rings: conquest for pc
That is an error with a specific Direct X file. If you did not install Direct X 9 with the game you should run the install again and this time let it do the install. If you still have the problem, then got to Start, then Run. In the Run box type dxdiag. This is a built in program that will check all of your Direct X files and fix any that are corrupted. If after running that program, you still receive the error, there may be a problem with the game. You will have to contact the software publisher to get support to help you.
