20 Most Recent Swisher E4 Swindaiwa 24.5cc 4-Stroke Engine Commercial Grade Articulated Hedge Trimmer #E4-HT4000 Questions & Answers
Not likely. But to eliminate that possibility try connecting a battery charge to the battery and try engaging the blades then. Also check all electrical connection in system for corrosion and tightness. Lastly With compressed air blow all dirt and debris from the mower, especially clutch area and Hydraulic pumps. Check tension on blade drive belt.
Swisher Garden | Answered on Oct 17, 2018
Go to a good tool shop or auto shop and get a can of 'Belt Conditioner'. Spray the Hydro belt and pulleys liberally and then drive it. Your manual is here, see Page 21
https://www.mowersdirect.com/manuals/swishermanualzt2450a_2.pdf
need to know the engine make and caopacity
the operators manual will have the capacity required
Swisher Garden | Answered on Sep 10, 2018
Swisher RK 10544 pull behind mower breaking belts - Fixya
www.fixya.com/support/t14407937-swisher_rk_10544_pull_behind_mower
Sep 21, 2012 - Also - is the belt snapping clean, or do you see a burnt, worn spot? Posted on May 28, 2010. Helpful 1; Not Helpful; Flag. Testimonial: "Thank ...
how to change the belt tension on Swisher FC10544BS 10.5 HP 44 ...
? 2:45
https://www.youtube.com/watch?v=zP3KPc32m5U
Jun 8, 2017 - Uploaded by Adventures In Living
link to mower: http://amzn.to/2sGS9uF how to change the belt tension on Swisher 10.5 HP FC10544BS 44 ...Missing: rk
how to change the air filter in the Swisher FC10544BS 10.5 HP 44 ...
? 2:26
https://www.youtube.com/watch?v=ykOhC5qyO74
link to mower: http://amzn.to/2r5MwcA how to change the air filter in the Swisher FC10544BS 10.5 HP 44 ...Missing: rk
How to Replace a Drive Belt on a Swisher Mower ' Hunker
https://www.hunker.com > Home Hacks & Answers > Garden & Lawn > Lawn Mowers May 18, 2011 - The drive belt on a Swisher mower, such as the Swisher trail mower, powers the blades located under the mower deck. The trail mower is a ...Missing: rk ‎10544
Swisher Garden | Answered on May 21, 2018
Check the fuel jet and make sure it is clean. If there is any dirt in it even though you cleaned the carb the unit will not run properly if any at all. I use an air compressor to clean mine ore a real fine piece of wire.
Swisher Garden | Answered on Apr 02, 2018
If this is just a mounting bolt it will be right-hand threaded meaning that with you looking at the nut/bolt, the nut will turn clockwise to tighten.
Some blade bolts (and some old car lugs nuts are left-hand thread on one side of the car, as is the left pedal on a bicycle) are left-hand threaded and it can get real exciting til you figure out you hand to turn them counterclockwise to tighten
Swisher Garden | Answered on Oct 09, 2017
The cost on the ones I can find (not for your machine) is in the $1700 range. Since your machine is obsolete, that one part is close to 20% of the cost of a new ZT mower. And the other side is just as old. Since it's already broken, tearing into it is not going to make any difference. Is there the possibility that you could take lots of pictures as you tear it apart and have a machine shop re-do/make your bad parts ? The new ones are made by machining, so it's not a stretch. Just have to find a machine shop willing to do the work.
If it works you could be the go-to guy for people in the same situation. :)
Swisher Garden | Answered on Oct 03, 2017
Drive belt may have broken or idler pulley could have malfunctioned or drive belt could have just came off alignment.
Swisher Garden | Answered on Sep 10, 2017
Swisher E4 Swindaiwa 24.5cc 4-Stroke Engine Commercial Grade Articulated Hedge Trimmer #E4-HT4000 Logo
Popular Tags
0 questions posted
Top Swisher Garden Experts
lnbn1975
dannydoesita
Jay Finke
Jay Finke
Are you a Swisher Garden Expert? Answer questions, earn points and help others
View Most Popular
Swisher Garden
  • Swisher Garden
Most Popular Question
size belt fits deck
  • Garden
