20 Most Recent
Ardisam 5.5 Hp Rear Tine Rototiller Questions & Answers
I have a 5 hp montgomery wards rototiller when
Filling to an indicator Level line on the box should be the norm.
on most Transmission boxes that is anyway. Usually If there is a Flush Plug on the side of the Box. This Would be around the minimum level to Fill & THEN + 2rds higher For The Level you should require.
Subject Scott/Ardisam Model 6070S Serial
Hello
I've the details for your Rototiller. "Ardisam RT Rototillers_operating instructions & part Explosion". But I can't send that document to you by this window, as this window does not allow me to upload PDF files. The document is in Adobe Acrobat PDF format. If you send your Email ID by Fixya, I'll send a copy of it to you by return mail. OK.
Can I get the specs for belt 727 A?
DID THE BELT SHRED OR what happened if it is still decent mesure width on top is it a v-shape belt or flat & last thing is cut it & measure it if its still decent that will give you the specs or if theres other # on belt & who its made by
Garden master tiller 5020d
Get behind the tiller as if you are ready to use it. Look down towards the tines. There's a protective cover. Remove it and you will see the belt running vertically between the motor and the tines.
Need a forward cable for a Scott's 6070s
Forward and reverse cables are interchangeable. I have found that if it's stuck, removing the cable, spraying WD-40 down the cable and working it in and out by hand often frees it up. Otherwise, order from Ardisam. I think I paid about fifteen dollars for the last one I ordered.
Garden star
I paid $250 for one. That seemed a good deal considering most where closer to or above $300
