20 Most Recent Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Questions & Answers
I had this exact problem.
Open the glass front. Take a piece of fine steel wool and clean the little metal ends where the flames ignite. Sometimes they just get gummed up. It prevents enough flow from getting through to maintain a flame.
Napoleon 36"... | Answered on Mar 24, 2018
You can't unless you a government registered gas fitter. Incorrectly installed or serviced appliances gas people and blow up homes. Get someone in to service it.
Napoleon 36"... | Answered on Jan 20, 2018
A thermcouple is what keeps pilot on, if your unit has both a thermocouple and thermopile then your pilot CAN stay lit and main burner not come on.do not buy a gas vavle untill you check the thermopile voltage!! very costy blunder.this is how you test it..( open circuit test) Disconnect thermopile leads from valve. take a volt meter set it to millivolts- set it to a mv reading above 500 so that you can test it correctly, my meter has 2000 setting and I use that. connect T/P leads to meter leads.. reading should be 500mv.
( closed circuit test) connect leads of meter to terminals that your thermostat or on/off swich are hooked too, usually top and bottom terminals on most gas valves, turn unit on and reading should be 150mv or more... you need try open circuit. I can test your vavle too if you like keep me posted if I helped or not. 15 yrs experience in gas repairs!!
Napoleon 36"... | Answered on Dec 07, 2017
see if clogged burner tubes if ok check gas valve
Napoleon 36"... | Answered on Sep 13, 2017
check voltage coming in
Yes and no......
If the fireplace wont turn on from that switch, Most likley a diffrent switch
Napoleon 36"... | Answered on Sep 27, 2014
Please define the ACTUAL PROBLEM please!
Napoleon 36"... | Answered on May 30, 2014
sounds like bad flame sensor this is a safety if it doesnt sense flame it will shut the gas valve off
Napoleon 36"... | Answered on May 08, 2014
Electrical short in the wires somewhere, at ignition control module, possibly. That what I would check for 1st, intermittent problems are the worst to diagnose, and sometimes the easiest?
Napoleon 36"... | Answered on Jan 29, 2014
Despite the simplicity of a Millivolt system,troubleshooting them is often not as simple, if you go by the book using a Volt/Ohm meter to test the generator and gas valve. The Pilot Generators are less tricky as they all put out 750 mv or 3/4 of a volt out of the system, in the system is where each result will be specific according to what gas valve is used, not all gas valves have the same ohm's values, and many newer gas valves cannot be ohmed due to the design!
They will read open every one of them.
The way to make it simple and assure you never get any call backs
is to take a AA battery and attach a wire to each end of the battery,
Radio shack sells battery boxes with leads built in for several dollars.
Remove the 2 leads from the gas valve coming from the pilot generator and replace them with the AA battery leads If the gas valve operates normally via battery, it is a good gas valve, if not it is bad.
If you apply voltage to the gas valve and get zero amp draw,the gas valve is bad. Do not leave the battery in place and operate the unit in this manner unless you are able to be diligently watching it, never sleep or leave etc, it is strictly for emergency use or testing.
Old time units had no pilot safety, the pilot valve was manually operated just like a garden hose, if the wind blew it out it still kept coming, however as natural gas is lighter than air it will vent if it is allowed to via the flue, propane units must have 100% safety for the pilots operation as propane is heavier than air and will not vent, it settles in the lowest spot making propane more dangerous in that respect than natural gas is.
750 mv is 3/4 of 1 volt, not much power, the thermopile makes this power by having 2 dissimilar metals co joined in the end of the thermopiles that impinges the pilot flame.
A temperature differential must be maintained across the thermopiles end, if the entire end of the thermopile is hot the power will drop off or stop all together, thus extinguishing the pilot.
Many homeowners make the mistake of setting the thermopile too far into the flame, heating the entire end, not just the top 1/3 portion thinking this will bake it into submission, or force it to make power when in reality it does the opposite.
Napoleon 36"... | Answered on Dec 16, 2013
by pass the switch, if fireplace runs, then replace the switch
Napoleon 36"... | Answered on Dec 05, 2013
Get someone to come and do this correctly. You have a possible carbon monoxide poisoning hazard!!
Napoleon 36"... | Answered on Nov 18, 2013
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
Popular Tags
125 questions posted
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Craig Butler
Craig Butler
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Napoleon Pool & Spa
  • Napoleon Pool & Spa
Most Popular Question
gas fireplace lights up but only half
  • Pool & Spa
