20 Most Recent
Hayward GO-KIT #2 HAYWARD SUPER II PUMP SERIES SP-3000 & SP-30 Questions & Answers
HF code on hayward 200fdn pool heater?replaced gas valve still have same code.What now?
HF
Flame present with gas valve "OFF" error
If flame is sensed with the gas valve off the control will go into lockout. The blower will run until error condition is corrected. When corrected, control will run blower for 5 s then automatically restart after 2 minutes.
the error might be caused by a faulty flame sensor. i have heard of this happening the other way (carbon blocks sensor causing no ignite)
New XtremepowerUS 2HP In-Ground Swimming Pool Pump Variable Speed 2 Inlet 230V High Flo w/ Slip-On Fitting, i turned it on after 2 mins switch from high to low then shut off and get very hot.
All electric motors run hot and pool pumps are no different. But how hot is too hot for a pool pump? The first test is simply whether you can touch the motor or not. Under normal operating conditions, the motor end of the pump is hot enough that you can barely touch it - but not searing hot.Best to you.https://www.google.com/search?q=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&newwindow=1&sxsrf=AB5stBhpriuNhnfXLYYTg7tuS-LWwW262g%3A1690815381903&source=hp&ei=lcvHZKH_NOHi9AOquJjADw&iflsig=AD69kcEAAAAAZMfZpVdAAi94QXZiwKfN3nArsWv-Gm1z&ved=0ahUKEwjhnd6RmrmAAxVhMX0KHSocBvgQ4dUDCAo&uact=5&oq=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&gs_lp=Egdnd3Mtd2l6IkpYdHJlbWVwb3dlclVTIDJIUCBJbi1Hcm91bmQgU3dpbW1pbmcgUG9vbCBQdW1wIFZhcmlhYmxlIFNwZWVkIHJ1bm5pbmcgdGVtcEgAUABYAHAAeACQAQCYAQCgAQCqAQC4AQPIAQD4AQL4AQE&sclient=gws-wiz#kpvalbx=_sMvHZMuPJPez0PEP3M2LgAY_44
How can I test if my Hayward gas heater water pressure is working??
Testing the water pressure of your Hayward gas heater is a relatively simple process. Follow these steps to check if your water pressure is working properly:
- Turn off the Gas Heater: Before performing any tests, make sure the gas heater is turned off to avoid any potential accidents or injuries.
- Check the Pressure Gauge: Locate the pressure gauge on your Hayward gas heater. It is usually located on the front panel of the unit or near the plumbing connections.
- Observe the Pressure Reading: The pressure gauge will display the current water pressure. It is typically measured in pounds per square inch (psi). The optimal water pressure for most pool heaters is usually between 15 psi to 25 psi, but it's essential to check your heater's manual for the specific recommended pressure range.
- Turn on the Pool Pump: Ensure that the pool pump is running, as it is responsible for circulating the water through the heater. The water pressure will be at its most accurate when the pool pump is operating normally.
- Monitor the Pressure: While the pool pump is running, observe the pressure gauge to see if the water pressure falls within the recommended range. If the pressure is below the minimum recommended level, it may indicate a circulation issue or a problem with the pool pump.
- Check for Leaks: While testing the water pressure, inspect the heater and the surrounding plumbing connections for any signs of leaks. Leaks can lead to reduced water pressure and affect the heater's performance.
What is a 1F code on the hayward pool heater
The code you are referring to is actually IF, not 1F. It stands for ignition failure.
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
AO error code on 250k btu hayward pool heater
Dear ,
Please try the below solutions,
Solution 1:
If the blower prover switch does not close after the blower starts the control will stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes
Solution 2:
If the blower prover switch opens unexpectedly during operation the control will shut down and attempt to re-light. If the switch does not close after the blower starts the control will go into lockout with the blower running. Automatic reset is immediate after error is corrected
Solution 3:
If the blower prover switch opens during the postpurge cycle (heater is not fir- ing) the control will display the error code. The post-purge cycle will be com- pleted once the blower prover switch close
Regards,
Samy
Hayward Pro Series S310S sand filter - can it be repaired?
You are not alone
https://www.google.com/search?q=Hayward+Pro+series+S310S+leaking+at+seams
Try applying JB Weld Epoxy putty. If you can drain it, remove the sand clean the seam and apply from the inside, it will last years, or from the outside, probably just a couple. It is a remarkable product. Apply to a clean dry surface for best results.
WaterWeld Epoxy Putty - JB Weld
https://www.jbweld.com > product > waterweld-epoxy-...
Ideal for repairing plumbing, fuel tanks, tub and shower, drains, pool and spa, boats and potable water tanks; setup occurs even under water. After curing, it ...
Our Hayward gas heater keeps giving us a H5 error
Could the Error code be HS? That is high temperature limit. Perhaps you' don't have enough flow,
allowing the heater to heat the water to a temperature higher, than the thermostat setting. Make sure your bypass valve is closed, allowing full flow through the heater. Check your filter pressure differential , and skimmer baskets.
You didn't give your model number, and there are many models. You can go the Hayward website below and select your exact model number and download the manual. The manual will explain each error code.
http://www.haywardnet.com/inground/products/manuals.cfm
