20 Most Recent Dolphin Maytronics Advantage Questions & Answers
possible bad belts or drive motor
Dolphin... | Answered on Nov 23, 2017
or bad drive motor
bad motor or transformer
replace the motor
Dolphin... | Answered on Jun 29, 2015
MAYBE YOU NEED NEW BRUSHES FOR IT , NEW WINDINGS OR A NEW FAN
drive belts on inside are worn and skipping over the gear on the inside. replace drive belts.
Dolphin... | Answered on May 31, 2015
Thank you for posting your question here on Fixya.com.
It can be a couple of possible issues which will require service at a service center. For warranty consideration, please fill out the contact information and a description of your problem on the dolphin service page at http://www.arrowpools.net/ (select Dolphin Service along the bottom) and we will respond with shipping instructions to begin the repair process.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Dolphin... | Answered on Sep 05, 2014
Found mauals on the Maytronics site.........Thanks for being there, though!!
Dolphin... | Answered on Jul 31, 2014
use a 1.5mm allen wrench to loosen the set screw in the side of the plug and then insert the allen wrench into the hole and bend the shim back to make room for the wires. The white goes into the 2 hole and the black into the 3 hole.
John
Dolphin... | Answered on May 23, 2014
if you have acess to another cord try that make sure connections arent corroded
Dolphin... | Answered on Mar 21, 2014
It sounds like you might have a problem with the impeller or drive shaft, which are both common problems with these pool cleaners. Clean around your impeller and your wheels, axles, etc. If these do not cure your problem, it is probably an issue with your electrical system.
Dolphin... | Answered on Oct 24, 2013
Dolphin Maytronics  Advantage Logo
137 questions posted
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Dolphin Pool & Spa
  • Dolphin Pool & Spa
Most Popular Question
dolphin pool cleaner runs fine along
  • Pool & Spa
