20 Most Recent Smartpool Nitro Robotic Cleaner and Caddy Questions & Answers
if power through cord then check drive motor
Smartpool Nitro... | Answered on Nov 30, 2017
if control unit going out bad transformer if unit not moving check drive motor
check motors if drawing too much amps will ruin transformer
if caddy has power bad drive motor if no power to caddy check transformer or board
see if pump is working maybe air trapped
Smartpool Nitro... | Answered on Nov 23, 2017
check drive belts or worn out paddles if ok check inside to see if motor is weak
Smartpool Nitro... | Answered on Apr 25, 2016
The fan is an indicator of the main drive motor...so if the fan is debris-free...then you've got a motor problem. Since you can't get replacement parts, you'll have to replace the main motor unit...around $200 with shipping. I've replaced mine, it's a relatively simple process for the DIY guy...and it extends the life of your nitro significantly. If you get three seasons out of your motor, you are doing good...anything more is lucky, anything less means you probably mistreated the little guy...like leaving it in the pool non-stop, or allowing it to run out of the pool which will quickly end the main drive motor life.
Smartpool Nitro... | Answered on Aug 28, 2015
Plug it in! :o)
Okay, assuming you have...do you get red or green lights on at the power supply? If so...that means:
1. you could have a connection problem between the power supply and the Nitro. You can check connectivity using a simple volt-ohm meter. Replacement cords can be purchased online.
2. One, or both of your drive motors are dead...usually, this because water enters the drive units. Replacing the motors is expensive...$140 or so for the front-wheel drive unit, and $185 for the big one in the center. But even then, these prices you have to search for...
Is it worth it? Hmmm, maybe...Robot cleaners are way too expensive...for what you get. So replacing motors every few years is better than paying $400 - $1000 every few years. These pool cleaners, like old cars, you can keep them going and going by replacing parts.
I am really happy with my Nitro...I put it in my 11,000 gallon pool about 3 times a month, and remove and clean the little guy out right after he is done. Then he goes in the storage rack out of the sun....and he is quite happy.
I used to leave him in the pool, for weeks at a time, and that was when I started running into problems with the motor units leaking...water has a LOT of pressure and is always trying to get in the motor units...and eventually it does. It;s been more than a year since I repaired the seal on my main motor, and replace the drive motor...and I expect a long life out of mine, which is now more than 3 years old and running strong.
Smartpool Nitro... | Answered on Jul 12, 2014
Smartpool Nitro Robotic Cleaner and Caddy Logo
56 questions posted
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
  • Smartpool Pool & Spa
Most Popular Question
nitro wall climber not move sits bottom
  • Pool & Spa
