20 Most Recent
Kindle Fire HD 8.9" 32GB, 4G Wifi Questions & Answers
Kindle user manual
Contact Amazon. They have a board that you can use with all sorts of answers. All mine took was a restart..
My screen freezes up? It happens every day.
Have you tried a complete reset? It has fixed my problems. Hold the power button down for at least ten seconds an the restart. Or got to the menu an click on reset to original. You won't lose any info just a restart.
My kindle fire 4g the volume is turned up but has no sound
Since it is basically sealed there is not much you can do about it. Is it still under warrentee?
However I once also had this same problem. It must have been some dirt or corrosion in the earphone jack. Try taking an external earphone and keep putting the tip into the jack several times. If it starts to work then that was your problem. If not then you need to contact Kindle and ask for repair.
Hope that it is just the earphone jack.
Good luck,
Marty
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
Rca 16mm projector 201 pg no sound exsiter lam of
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX9MCToeeCAxWXv4kEHeF-DZcQFnoECCEQAQ&url=http%3A%2F%2Fwww.film-tech.com%2Fubb%2Ff1%2Ft000301.html&usg=AOvVaw3MnkgK0sKTHX7t5pvECIT5&opi=89978449
Lanzar sd82 input output plug layout
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi8krnznueCAxWxrokEHT0iBfoQFnoECA4QAQ&url=https%3A%2F%2Fwww.manualslib.com%2Fmanual%2F577337%2FLanzar-Sd82.html&usg=AOvVaw1NvtQPbnDX49X9-I6oRe-J&opi=89978449
