20 Most Recent Microlife 3MQ1 Blood Pressure Monitor Questions & Answers
make sure ther in the right way and then try it again sounds like BAd Contention on the side of the Batteries maybe worn spring
Microlife 3MQ1... | Answered on Feb 27, 2015
With power on, showing only clock.
Press M button, then press Power button together.
About 10 seconds, it'll display CL on screen.
Lift up your finger, CL will flashing.
Then press M button once, you'll hear 3 beep
Done.
Microlife 3MQ1... | Answered on Sep 23, 2014
hi.
there is no customer serviceable parts in your machine.The calibration can only be done by the manufacturer. Please contact Customer Service at 1-800-568-4147 to
arrange the test.
Good luck and thank you for consulting fixya.
Microlife 3MQ1... | Answered on Aug 02, 2011
Hold the memory button in for 7 seconds.
Microlife 3MQ1... | Answered on Mar 31, 2011
Blood pressure monitors can frequently become uncalibrated. First make sure that your batteries are fresh since one's running low on a charge can give faulty readings. If this doesn't help, contact the manufacturer, they recommend calling them at 1-800-568-4147 every couple years to arrange for an accuracy test. Page 20 of their manual should help a bit more.
Microlife 3MQ1... | Answered on Mar 13, 2011
it should turn itself off
Microlife 3MQ1... | Answered on Apr 09, 2010
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Microlife 3MQ1... | Answered on Feb 13, 2010
contact your vendor.
Microlife 3MQ1... | Answered on Oct 14, 2009
Google (Microlife)(BP3NQ1-4Z)(manual) without parens
Microlife Health... | Answered on Oct 29, 2016
Microlife 3MQ1 Blood Pressure Monitor Logo
30 questions posted
Top Microlife Health & Beauty Experts
Harrie
Tom Chichester
Erik Walters
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Microlife Health & Beauty
Most Popular Question
clear memory microlife bp 3ar1 3p
  • Health & Beauty
