20 Most Recent Salter 2001 electronic kitchen scale Questions & Answers
i have the same problem- did you manage to fix it??
Salter 2001... | Answered on Feb 28, 2018
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
The batteries may have been installed with the wrong polarity
Salter 2001... | Answered on Sep 05, 2016
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
Salter 2001... | Answered on Apr 09, 2016
Is it possible you put the batteries in the wrong way? Sometimes a device will still have power in that situation, even though it won't work as expected. Try a new set of batteries, but clean the contacts in the battery compartment first, and double-check the battery orientation.
Salter 2001... | Answered on Dec 20, 2014
Number of grams multiplied by .0022 = lbs,
Salter 2001... | Answered on Dec 10, 2014
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Salter 2001... | Answered on Oct 21, 2014
i needs manuals of calibration of the scale salter model 6055
Salter 2001... | Answered on Sep 13, 2014
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
EE showing on screen
Salter 2001... | Answered on Sep 12, 2014
What exactly is the problem. Can you upload a picture?
Salter 2001... | Answered on Jul 01, 2014
Salter 2001 electronic kitchen scale Logo
125 questions posted
Top Salter Health & Beauty Experts
vince
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Salter Health & Beauty
Most Popular Question
my soehnle scale shows an out2 error how
  • Health & Beauty
