20 Most Recent
Gardner Bender Analog Multimeter: Meter. 5-Function 12-Range GMT-312 Questions & Answers
How do i check ohms on coax tv cable
That is not something that you can do to specification. The resistance of that wire is actually the impedance. You are going to only be checking for continuity by setting a meter to the ohm setting and then either short one end against itself and check the other end or use both ends and put one probe on the collar and one on the center conductor. The meter should swing all the way to the right.
Testing amps with a gb GDT 294a
you need to connect your unit in DC Amps mode in series with charger when in use BUT be careful that anything over 10A will blow the fuse
How to set GDT-311 Digital Multimeter to x 1000 ohm setting?
The 20K setting is close to what you're looking for. The 200 scale is best to read 0 to 200 ohms, the 2K setting would be to read 200 to 2K, the 20K is to read 2K to 20K, the 200k range is for 20K to 200K and finally, the 2000K is to read 200K to 2000K or (2M) ohm resistance.Basically, start on the high range, and work your way down until there is only one (or none) digit after the decimal point in the display for the best accuracy. A 6,500 ohm value may display as .006 reading on the 2000K range, and as you can see, doesn't give a true reading of the actual value. I hope this helps!
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
