20 Most Recent Eaton Corporation GFCB115 GFI Circuit Breaker Questions & Answers
How to reset Culter Hammer GFCB115
Hi Tenny,I'm an electrician and can help with this problem. First, did you just install this breaker - or was it working before? If you installed it - skip down to the end.If it was working before, I can tell you that resetting a GFCB115 is the same as any other "regular" circuit breaker in the panel: 1) Clear the source of the fault.2) Push the breaker handle from the "Tripped" (or mid) position to "Off"3) Push the breaker handle from "Off" to "On"That's it. Most times, people skip #1 and go right to #2. If the breaker handle fails to remain in the "On" or immediately moves to the "Tripped" position after or during a reset operation, one of two things is wrong: 1) The breaker is defective. This does not happen that often - but it does happen now and then. 2) The offending load has not been cleared. This is more likely to be the case. Start by trying to isolate the source of the fault which many times is the most recent device connected to an outlet. One by one, unplug the devices on the circuit and power up to see if the breaker "holds" the load without tripping. Once it holds, it is a safe bet that this last device is the source of the problem. Reinsert all the plugs back into the outlets - except the last one. If the breaker is still holding, the device that was left unplugged is probably the culprit and will need to be checked out before connecting again. It is NOT advised to simply use the device on a non-GFCI protected circuit. There is probably an issue with the device - and it will be present on the non-GFCI circuit that could result in shock, burns or loss of life. Keep in mind, most GFCI circuit breakers will trip when a ground fault or a current overload is detected. There is no distinction or indication if the breaker tripped due to one condition or the other. If it has tripped due to overload, clearing the fault is done by simply reducing the load on the circuit. Once the load is reduced, the breaker will reset normally.If you just installed it and it won't work, tell me how you connected it to the panel and how you connected the circuit to it.I hope this helps and good luck!
5/3/2012 8:51:12 PM • Eaton... • Answered on May 03, 2012
I turned it off for about six months, now it will
you must push it kind of hard to get it to reset. first kill the 100 anp or 200 amp breaker. that is what most of sizes used now days. it will be the big wide breaker. now pull the wire our of your eaton breaker. if it has 2 wires pull them both. it has just one pull it. move it back where you wont touch it or it wont touch anything else. now reset it again. it it resets you have a bad short down the line. let me know and i will help you run it down. good luck and good day. sawdust46
7/31/2009 5:12:52 PM • Eaton... • Answered on Jul 31, 2009
Trouble wiring up my Eaton PT18M minute timer to my bathroom fan.when I turn the breaker back on in my breaker panel the fan turns on but will not turn off and there is no lights on on the switch
The timer black and red wires have to be in series (inline) with the black voltage supply and the black to the fan.
4/24/2022 10:47:53 PM • Eaton Electrical... • Answered on Apr 24, 2022
Should an eaton 20 amp "all-in-one" breaker come with the coiled white "pigtail" they refere to in the installation instructions?
If it is Plug On Neutral (PON) panel then a neutral wire is not needed.
7/22/2019 3:53:40 PM • Eaton Electrical... • Answered on Jul 22, 2019
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the syst
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
5/4/2017 6:22:56 PM • Eaton Electrical... • Answered on May 04, 2017
What is fault code #06 in EATON 40KVA?
Be clear what is the equipment of 40kva?
2/6/2017 10:51:54 AM • Eaton Electrical... • Answered on Feb 06, 2017
2answers
The test button on my 15 amp eaton breaker does not reset when pushed.
spring inside has come off, or their is no power going to it.
12/22/2015 4:59:13 AM • Eaton Electrical... • Answered on Dec 22, 2015
What is the RTDF FIB alarm?
Because is an Eaton I would call them they will be able to walk you through and how to clear it. Or you can try to look it up but good luck http://www.eaton.com/Eaton/ProductsServices/Electrical/ProductsandServices/ElectricalDistribution/ProtectiveRelays/MotorRelays/CH-Series/MP-4000/index.htm#tabs-2
11/6/2015 4:47:39 PM • Eaton Electrical... • Answered on Nov 06, 2015
What voltage and amperage is required to trip a shunt trip unit
The circuit breaker will have a shunt trip voltage & current ratings, a variable current selector knob, etc. - based on the type breaker (Catelog number). Here is a link to images of C-H shunt trip devices and circuit breakers cutler hammer shunt trip circuit breakers parts Google Search If you can provide the catelog or model number - I 'll be able to provide add'l help.
3/12/2014 12:34:56 AM • Eaton Electrical... • Answered on Mar 12, 2014
Amperage requirded to trip the shunt
depends on the rating lighting is 5-7amp, wall sockets 13 - 20 amps (depending on model number can be 7amps), cooker 30amps.
3/11/2014 7:06:53 PM • Eaton Electrical... • Answered on Mar 11, 2014
Not Eaton but Square D.
you say you have a square d panel and you have a eaton breaker this may be the problem square d should always have a square d breaker and eaton with eaton they dont fit wright in the panel they are made for each other ,you should check the panel and breaker to see if all the wires are tight if there is no problem there check the plug in the wall if there all tight ,it may be drawing to many amps and blowiing the breaker,
9/14/2011 12:56:37 AM • Eaton Electrical... • Answered on Sep 14, 2011
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
Eaton Corporation GFCB115 GFI Circuit Breaker Logo
Popular Tags
2 questions posted
Top Eaton Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you an Eaton Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Eaton Electrical Supplies
Most Popular Question
reset culter hammer gfcb115
  • Electrical Supplies
