20 Most Recent Biostar P4VMA-M Motherboard Questions & Answers
Yes, replace your cmos and it should be working again
Biostar P4VMA-M... | Answered on Sep 21, 2017
Yes, it does! You may refer from its manual for the location and full specification of your Biostar P4VMA-M thru this LINK. Read thru pages 6 onwards.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Biostar P4VMA-M... | Answered on Jul 09, 2015
go here to download driver bio http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=252
Biostar P4VMA-M... | Answered on May 25, 2014
Hello, this old motherboard socket 478 does not support windows 7, only xp.
Biostar P4VMA-M... | Answered on Aug 29, 2012
press f10 when bios begins to boot this will allow you to select your boot sequence put cd/dvd drive first to boot then hdd
Biostar P4VMA-M... | Answered on Sep 02, 2010
download the torrent named cobra driver pack from www.piratebay.org and make dvd. it contains almost all the driver and it will install the driver automatically.
Biostar P4VMA-M... | Answered on Jun 25, 2010
dude are there 2 driver if yes then u have to set the priority
u have to make one primary and the other secondary drive via the bios settings
Biostar P4VMA-M... | Answered on Feb 15, 2010
http://img.photobucket.com/albums/v242/Saphirex/wdsata2.jpg
http://img.photobucket.com/albums/v242/Saphirex/wdsata22.jpg
Biostar P4VMA-M... | Answered on Jan 12, 2010
http://www.biostar-usa.com/mbdownloads.asp?model=P4VMA-M
There is your manual for your MoBo Biostar P4VMA
You can download it, or youst read it online and you can download drivers if you need.
Thanx Using FixYa
If you find my answer helpfull, please dont forget to vote!
Good luck to you
nic
Biostar P4VMA-M... | Answered on Dec 11, 2009
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Biostar P4VMA-M... | Answered on Dec 07, 2009
From the manufacturer's web-site:
http://www.biostar-usa.com/app/en-us/search/search.php?search=P4VMA-M
select either the 'P4VMA-M 7.x' or the 'P4VMA-M 2.3' motherboard, and click on 'MANUAL'. Click to download and "save" the '.EXE' file to some folder on your computre. Run that '.EXE' file to create a PDF file in the same folder. Open the PDF file, and scroll-down to page 10, which has a large annotated diagram of the front-panel connectors.
Biostar P4VMA-M... | Answered on Nov 20, 2009
have you had problems with your computer being slow? if this is the case, chances are you have a big virus and the computer can no longer read your hard drive. This will also make it much more difficult to to reinstall the OS. I would suggest taking it to a local computer store, not a box store, and get them to reinstall the OS. It sounds like you may have a boot virus. If this is the case, it also means you will not be able to retrieve any information you had on your hard disk prior to this incident. Let me know if this is the issue. If not, we'll try to figure out something else.
Biostar P4VMA-M... | Answered on Oct 05, 2009
Check the mains power supply cable. Try to Connect with another cable. Or, the SMPS power supply unit may be at fault.
Biostar P4VMA-M... | Answered on Jun 24, 2009
Me parece que usted está usando español. Antes que podemos chequear su problema, necesitamos que nos da el Fabricador de la computadora y el número del modelo. Por favor necesitamos los sintomas, como les ha visto acontecer. Una vez que tenemos la información me voy a trabajar y hacer una duplicación de su problema en nuestro laboratorio. En esta manera no vamos a darlo estimaciones, pero sugerencias concretas. Muchas gracias que usted decidió usar nuestro servicio.
Mi nombre es Constantino (arzconst)
Biostar P4VMA-M... | Answered on Jun 02, 2009
Dear Sir; without an instruction manual of your motherboard, I don't suggest that you, ever connect the wires, or attempt to turn it on, ON GUESS ONLY. From what I see you have all the info you need. Go to Biostar and buy a manual. They only cost about US$ 10.00 and then follow instructions to an iota. You are playing with fire...
My name is Constantin (arzconst)
Biostar P4VMA-M... | Answered on May 31, 2009
If your trying to install it over the current installation then select Format at the installation screen of XP setup. In order to do that you would have to boot from the disc, that way you don't have to load windows. Also when you have completed and installed XP, try to locate some software to detect what drivers you need. I use driver detective and it worked fine for me, or alternately send me a message and ill run you through how to check the motherboard for the version manually.
Biostar P4VMA-M... | Answered on Mar 27, 2009
good day,
have you tried unplugging and replugging the cable connecting from the monitor to the video card? if after trying that it your video card is still not functioning, try installing a separate video card in its appropriate slot and try if this will work. better yet, have it checked by a competent technician in your area to verify other possible causes of this problem.
i hope this will help
Biostar P4VMA-M... | Answered on Feb 26, 2009
Try to install from here:
www.drivers-software-download.org/tag/audio-driver-biostar-p4vma-m-ver-78 - 56k -
or
www.motherboard.cz/mb/biostar/P4VMA-Mv23.htm - 47k -
Biostar P4VMA-M... | Answered on Jan 19, 2009
Biostar P4VMA-M Motherboard Logo
35 questions posted
Top Biostar Computers & Internet Experts
Jayburt
Ekse
Thomas F. Schneider
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Biostar Computers & Internet
Most Popular Question
biostar p4vma m ver 7 8 support sata
  • Computers & Internet
