20 Most Recent Biostar iDEQ 330G (IDEQ330G) Barebone Questions & Answers
As I recall, this model has one IDE channel on, which typically powered an optical drive. The manufacturer claims that it supports one IDE drive, in theory, you could set the IDE HDD on the second connector of the IDE cable (secondary slave), however, it may be that the Bios will not recognize this.
My own thoughts would be, as this has 2 SATA ports, to leave the IDE connection alone and for the Optical drive and put another SATA HDD on the other SATA connector.
If you need to use the IDE drive, you can get an IDE to SATA adapter and that would enable you to use it connecetd to the SATA connector
As to capacity, I'd assume it would run any size of HDD
Biostar iDEQ... | Answered on Jun 23, 2011
Biostar motherboards have a 1 year warranty and require proof of purchase.
http://www.biostar-usa.com/app/en-us/support/rma.php
Biostar... | Answered on Aug 19, 2019
if you have an internet access... use windows update
Biostar... | Answered on Mar 26, 2019
Try another mobo or another set of ram figure out which is bad
Biostar... | Answered on Mar 18, 2019
Find drivers with 3Dp chip Software
http://www.3dpchip.com/3dpchip/sub/chip_eng.html
Biostar... | Answered on Jul 17, 2017
Not sure how u shorted it out installing ram. Theres only 1 way the put it in and there should have been NO power on the board at the time. AND I'd like to know how you think the board is shorted out. What is happening? It's a very rare occurrence and there are other easy fix issues that might make a person think the board is fried. Let me know your answers to these questions so I can help further.
Biostar... | Answered on Apr 13, 2017
clone the bios from the website of biostar
Biostar... | Answered on Jan 29, 2016
No, Biostar advertises that you should use low voltage memory on this board. My experience that when 1.5 volt memory is installed in a 1.35 volt system, it is not reliable. (Intermittent Crashes.)
You would have to increase the memory voltage, this is only possible on full blown gaming motherboards designed for overclocking the memory.
A j1900NH2 supports S states, but it does not support memory overclocking.
Biostar... | Answered on Dec 22, 2015
many things enter into your problem . memory size is the biggest no doubt .
Biostar... | Answered on Aug 17, 2015
See the manual:
ftp://ftp.biostar-usa.com/manuals/M7VIG%20400/M7VIG400manual.pdf
Page nr. 9 you cane see JPANEL1 pin assignement.
Biostar... | Answered on Mar 30, 2015
Some idea of your question would be good
Biostar... | Answered on Feb 10, 2015
Without you describing the problem it's impossible to suggest solutions, except purchasing another board. 6 months is a lot of time. I would get rid of this motherboard an bought another brand ( Gigabye, Asus are excellent brand names).
Biostar... | Answered on Jan 24, 2015
Hi
I went to the download drivers page of the BioStar website for your mobo here:
N68S3B
and the VGA driver for Vista and Windows 7 is the same one 8.15.11.8634 (the "x86" indicates 32-bit, but the driver looks to be the same for both 32 & 64 bit).
Your question about the AMD Athlon can be answered quite easily. It is a CPU and does not need any specific driver. You should however download and install the chipset drivers for the mobo.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Biostar... | Answered on Dec 24, 2014
Does it say after boot up I'm guessing u need to install display drivers but if that doesn't work give me more info please
Biostar... | Answered on Sep 07, 2014
You posted a motherbord name, but no question
Biostar... | Answered on Sep 04, 2014
clean RAM or replace it
Biostar... | Answered on Aug 10, 2014
Biostar iDEQ 330G (IDEQ330G) Barebone Logo
Popular Tags
1 questions posted
Top Biostar Computers & Internet Experts
Jayburt
Ekse
Thomas F. Schneider
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iDEQ Biostar
  • iDEQ Biostar
Most Popular Question
largest hard
  • Computers & Internet
