20 Most Recent
Blanco 157-090-ST Rados Kitchen Faucet Satin Nickel w/ Black Pull-Out Spray Questions & Answers
Same as previous poster. We
The only way to try and get it back is to unhook the hoses from the water feed lines....then unhook the sprayer from the hose...
Now open the faucet wide open in the warm position...
Then using a blow gun on an air compressor tank, blow air backwards through the valve body of the faucet...
This should blow any residual dirt back and out through the hoses...
Then reassemble everything and you should be back in business!!
heatman101
7/23/2011 5:04:26 PM •
Blanco...
Answered
on Jul 23, 2011
Replace the cartridge in a model 157075
I watched a video on YOUTUBE that Blanco posted on how to replace a cartridge in their faucets. It goes step by step and outlines everything you need to make the change.
Leak at new strainer waste fitting
Did you put the rubber gasket and cardboard sleeve on the bottom of the sink(next to the nut and did you use plumbers putty on the top part of the sink under the top section of the basket. Hint if you put some soap on the gasket under the sink between it and the nut it will be easier to tighten also you must secure the top part of the basket as you turn the nut if not the plumbers putty will not seal. If you do not have the strainer basket holding tool wrench you can substitute with a pare of needle nose pliers. Large channel locks or pliers can work to turn the large nut on bottom. If you can recruit a helper to hold the top part of the strainer basket with the needle nose pliers it make the job of tightening the large nut easier. When a large amount of the plumbers putty has squeezed out and the strainer is flush with the sink you should have a tight seal.
Blanco Eye Kitchen tap cold water is leaking from
Hello doy.. get a can of WD-40 penetrating lubricant and spray it on the seam connecting the lever and the body. It will penetrate within an hour or so. Repeat if necessary.
Also use a plastic head or a rubber head hammer to tap it up.
Joe
Thanks for choosing Fixya!
Have single handle faucet with
Check under the sink at the valves that the hot and cold water lines are connected to. See if the hot water one is turned on all the way.
JOe
I have a Blaco eye
Be very careful. I had a plumber help be and we ended up breaking the value with the bit stcu inside the handle. I managed to source a new handle, GBP12 plus VAT, but can't get hold of the valve!
