20 Most Recent Bosch 24 in. SGS66E02 Exxcel Built-in Dishwasher Questions & Answers
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Bosch 24 in.... | Answered on Apr 13, 2019
get the dishwasher filtration system at www.dishwasherfilter.com. this product was made to solve this problem. awesome product and guaranteed results.
Bosch 24 in.... | Answered on Jun 26, 2013
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
check these error codes.
http://fixitnow.com/wp/2010/09/01/bosch-dishwasher-test-programs-diagnostic-mode-and-error-codes/
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
For spares click On:
http://www.espares.co.uk/search/dishwashers/p/1083
Thank you for using Fixya.
Bosch 24 in.... | Answered on Aug 09, 2011
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Bosch 24 in.... | Answered on Mar 29, 2011
Will work just as well, in fact if you are using a wash that is lower than 50 degrees it will work better.
All the best.
Bosch 24 in.... | Answered on Aug 21, 2010
h:01 means 1 hour delay. Press the delay button repeatedly to get to h:00 then hit start.
Bosch... | Answered 14 hours ago
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Bosch... | Answered 19 hours ago
You can google your question for answer
About 15,800 results (0.65 seconds)
Took about 2 seconds to find answer. Look in the instructions that came with unit.
ttps://bosch-dishwasher-errors.com/bosch-dishwasher-error-code-e04/
Bosch... | Answered 22 hours ago
John, you might have a problem with your dispenser mechanism. You can remove it from the door and inspect it to make sure the door spring and tripping mechanism are not damaged. If any of these items are damaged, you can buy them separately and save some money. If you can't trouble shoot these or the main unit mechanism is damaged, you just replace the complete unit. It is not difficult to replace the complete unit. This YouTube video can help. https://www.youtube.com/watch?v=MDideDjjuEU
Good luck.
Bosch... | Answered on May 14, 2019
Bosch 24 in. SGS66E02 Exxcel Built-in Dishwasher Logo
14 questions posted
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
dishwasher displays e17 programe display
  • Dishwashers
