FixYa.com
Bosch 24 in. SHU30 Built-in Dishwasher
All Products > Bosch > Dishwashers
Problems with Bosch 24 in. SHU30 Built-in Dishwasher?
Troubleshooting and Support
Solved Problems for Bosch 24 in. SHU30 Built-in Dishwasher RSS Feed Post a New Problem
stuck on first step of cycle (water...
my bosch shu3036uc is stuck on the first step of the cycle witch is draining the residual water. the rotary switch is...
1 Solution
Water leak on fill cycle
The dishwasher model is actually SHU3012UC/U06, but that is probably irrelevant in this case. The water leak happens...
1 Solution
dishwasher issue
My dishwasher builds water inside the bottom. It's like not draining when dishes are washed completely. what do i do?
2 Solutions
prolonged washer cycle time
My washer is taking too long to complete. The "delay start time" keeps popping up with 2H, which I think...
1 Solution
miele G575 Dishwasher
Hi, The dispenser flap on my Miele G575 dishwasher not infrequently fails to open at the correct part of the wash...
Post a Solution
Fisher and paykel 913T soft touch...
My unit seems to be leaking in front bottom corners . As I have purched second hand I was wondering if a lower rubber...
1 Solution
Thermal fuse for Whirlpool Quiet Partner...
i have replaced the thermal fuse for the dishwahser above twice now. First time i did not replace the wires and it went...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeBuilt-in
Control TypeRotary Dial · Push Button
Number of Wash Cycles2
Dimensions
Depth22.44 in.
Height33.88 in.
Width23.56 in.
Bosch Contact Information
Main support number01895 878093
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
