20 Most Recent
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Questions & Answers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Rust spots on Bosch STAINLESS dishwasher
Debruce Polish is the answer. It is non-toxic and odorless, DeBruce will remove the rust and pacify the finish. DeBruce is perfect for touch ups and great on ceramic cook tops and more. We buy DeBruce polish at debrucepolish.com.
How to change detergent dispenser on Bosch SHY56a
Hello, walter
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Hi i have a Bosch
It is either the waste water pump has stopped working, whichis accessible from below the dishwasher (lay dishwasher on back and remove 2screws from bottom plate) or alternately the float (open dishwasher door, removebottom basket and lift dome shaped float up and down a few times).
Lower spray arm no water
Clog or hose has blockage. You will have to trace down if the water is feeding into the dishwasher but my guess is that you have a problem with the feed hose. Get a manual and find where the water feeds into it.
How do you check for
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
