20 Most Recent Pyle Pro Pt659du Dual Cassette Deck With Mp3 Questions & Answers
How do I pyle converter to convert from cassette to mp3
Henry hi! You need a computer with the necessary software and soundcard.
11/25/2014 5:41:29 PM • Pyle Pro Pt659du... • Answered on Nov 25, 2014
The db meter react correctly on the front display of the Pyle PT3300 amplifier when I play my music, but I can't get output power at the speaker connections. What should be the problem?
Speaker blown. Amp blown. Volume issue. Could be anything. I woud check the wiring and speaker first.
3/4/2024 7:51:11 PM • Pyle Audio... • Answered on Mar 04, 2024
Pyle PTA44BY Receiver. I can't get sound from it? I put wires in for speakers and no sound.
Question edited for clarity and typos. The Bluetooth isn't correctly paired. You are only half connected. https://www.fixya.com/support/r26362721-pairing_bluetooth_devices STEPS FOR CONNECTING WITH BLUETOOTH DEVICE Once paired you can play music from your Bluetooth device. You can also use the control buttons on the unit to select the tracks from your Bluetooth device. 1. Press MODE button to choose Bluetooth mode, display BLUETOOTH on the screen. 2. Search on the Bluetooth device name from others Bluetooth device and you can and the Bluetooth name - PYLEUSA 3. Select the PYLEUSA Bluetooth name and wait for the device to pair. 4. The PTA44BT will emit a noise confirming that the devices have successfully paired..
PTA44BT
Pyle USA http://manuals.pyleusa.com > PDF > PTA44BT PDF PTA44BT. 4 Channel Audio Amplifier. Multi-Source 1/4" Audio/Microphone inputs ... PyleUSA.com ... Read these instructions thoroughly before using this item. 9 pages
PYLE PTA44BT USER MANUAL Pdf Download ' ManualsLib
ManualsLib https://www.manualslib.com > ... > PTA44BT View and Download Pyle PTA44BT user manual online. 4 Channel Audio Amplifier. PTA44BT amplifier pdf manual download. ..
7/19/2023 3:28:35 AM • Pyle Audio... • Answered on Jul 19, 2023
Hi, when I first turn on my Pyle PT260A and goes to the tuner icon, the initial volume is very loud. I always have to be prepared to turn the volume down before it blares.
That normally happens when the memory battery on the motherboard fails. It no longer remembers what your last setting was. No service manual for it. https://www.google.com/search?q=Pyle+PT260A ...
3/22/2023 6:33:45 PM • Pyle Audio... • Answered on Mar 22, 2023
Pyle PBMSPG190 can't scan fm stations
If you're having trouble scanning FM radio stations on your Pyle PBMSPG190, there are a few things you can try:
- Check your antenna: Make sure your FM antenna is properly connected to your radio and is positioned in a location with good reception. If your antenna is damaged, you may need to replace it.
- Check the FM frequency range: Make sure that the FM frequency range of your radio is set correctly for your location. In some cases, FM frequencies may differ depending on your country or region.
- Check for interference: Electronic devices such as smartphones, tablets, or other nearby radios may cause interference with your radio's ability to pick up FM stations. Try turning off nearby electronics or moving your radio to a different location to see if this improves reception.
- Manually tune to specific frequencies: If the automatic scan is not working, try manually tuning your radio to specific FM frequencies to see if you can pick up any stations.
If none of these steps work, it's possible that there may be a problem with the radio's internal components. In that case, you may want to contact Pyle customer support for further assistance.
3/14/2023 2:57:54 PM • Pyle Audio... • Answered on Mar 14, 2023
My pyle boombox turned on but no sound in any mode
If your Pyle boombox has turned on but there is no sound in any mode, it could be caused by a problem with the speakers, the audio output, or a software issue. Here are a few steps you can try to troubleshoot the issue:
  1. Check the speakers and ensure they are securely connected and not damaged. Make sure the volume is turned up and the audio source is set to the correct input.
  2. Check the audio output and ensure it is not set to the wrong output. Make sure the audio output is set to speakers and not headphones or Bluetooth.
  3. Check the audio source and ensure it is properly connected and working. Make sure the audio source such as a USB, SD card, or Bluetooth is properly connected and that the sound is not muted.
  4. Try resetting the boombox by unplugging it for a few minutes and then plugging it back in. This will force the boombox to restart and may resolve the issue.
  5. If the above steps do not resolve the issue, it may be necessary to have the boombox serviced by a professional technician.
1/14/2023 10:06:28 PM • Pyle Audio... • Answered on Jan 14, 2023
My Pyle Pt694bt is in protect mode how do I reset it or where do I get it repaired?
Hi, you can use the instructions in the product manual to help factory reset your device. Otherwise, you can take it to a store like Geeksquad/Bestbuy in order to get the device factory reset on your behalf. But you might want to call ahead first to ensure that location has access to the manual in order to perform the factory reset. Thank you.
11/17/2022 10:51:49 PM • Pyle Audio... • Answered on Nov 17, 2022
Is my Pyle Pro PYD1955 Mixer having a fuse problem or something more serious?
Probablyna power supply issue in the mixer. Check for the correct voltages coming from the power supply.
3/8/2022 7:27:20 AM • Pyle Audio... • Answered on Mar 08, 2022
I have a Pyle PD6BU receiver . All of the sudden when I increase the volume there is a lot of static and crackling. Any ideas?
Depending on the age of the unit, if it uses the old style control knobs they can get dirt in them and produce that effect. Cleaning with switch cleaner will solve that. Otherwise if the noise is on one channel it could be faulty transistors. If it is on both channels then you are looking for something common to both channels. But not the power supply. Check if the device uses an STK chip amplifier. I'll post a picture of what it might look like. If it does then that could be faulty. power ic-undefined-undefined-0.jpg
6/5/2021 3:35:57 PM • Pyle Audio... • Answered on Jun 05, 2021
Where can i get a PYLE PRO PT-2000 Service Manual for free
Contact Pyle directly to inquire.
1/12/2021 4:55:14 PM • Pyle Audio... • Answered on Jan 12, 2021
Model 3301 receiver. Why is it making a pop(p)ing sound?
A steady popping sound called motorboating was a common fault in the early days of the transistor radio and not so common today. Back in those days the fault was usually found at the front end in the tuned circuits but I understand the condition can have a variety of causes. Below is a link to the Wikipedia article on the subject... https://en.wikipedia.org/wiki/Motorboating_(electronics)
1/9/2021 11:07:41 PM • Pyle Audio... • Answered on Jan 09, 2021
2answers
How do I change region code on Pyle pd1000a? Need region 1 and all I get is not formatted to play in this region error message. Don't know what region this thing is programmed to but need to change. P
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player. Region 1: U.S. and U.S. Territories, Canada Region 2: Japan, Western Europe, Middle East, South Africa Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/ South America Region 5: Russia and the former Soviet Union, Africa, Indian subcontinent, North Korea Region 6: China The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is legal in all countries. Google for the programs. A DVD player sometimes allows you to change the region code once. But it not even would allow you to switch back after you changed it once.
2/17/2020 3:49:53 AM • Pyle Audio... • Answered on Feb 17, 2020
I have the pyle PDIC83T speakers and how do I know what setting to put each speaker on, I will have 4 in one big room?
Hello Patt, the configuration of the speakers will depend on their height, surface to cover, and distance between them, as well as the amplifier to use As an initial test, put the selector switch of each speaker for the 10-watt position and test the result Depending on this test, you will have to raise or lower the power, to achieve the best coverage I hope you serve the suggestion Greetings Franco Dosil Hola Patt, la configuracion de los parlantes dependera de su altura, superficie a cubrir, y distancia entre ellos, como asi tambien el amplificador a usar Como prueba inicial, ponga la llave selectora de cada parlante para la posicion de 10 watts y pruebe el resultado Dependiendo de esta prueba, tendra que subir o bajar la potencia, para lograr la mejor cobertura Espero le sirva la sugerencia Saludos Franco Dosil
4/23/2019 4:00:41 AM • Pyle Audio... • Answered on Apr 23, 2019
Pyle Pro Pt659du Dual Cassette Deck With Mp3 Logo
1 questions posted
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pyle Audio Players & Recorders
Most Popular Question
pyle converter convert from cassette mp3
  • Audio Players & Recorders
