20 Most Recent Bosch 9.1 cu. ft. / 258 liter Upright Freezer GSU29424GB Questions & Answers
2answers
The alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
6/23/2013 4:46:57 AM • Bosch 9.1 cu.... • Answered on Jun 23, 2013
Wiring diagram for bosch exxcel fridge
I would like the schematic wiring diagram for a Bosch upright freezer, model No GSU23420GB/01 please?
6/17/2023 8:49:38 AM • Bosch Freezers • Answered on Jun 17, 2023
Bosch remove ice bucket freezer
I don't know but was hoping you had figured out how by now and could help me!
7/21/2021 11:53:02 PM • Bosch Freezers • Answered on Jul 21, 2021
BOSCH FREEZER INTELIGENT 32 is not turning on + the Alarm remains permanently connected.
Thermostat or control board problem if compressor not running at all.
1/6/2019 7:03:02 PM • Bosch Freezers • Answered on Jan 06, 2019
0answers
Where is the condenser coil on a built in fridge freezer
Usually at the rear in the bottom of the freezer regardless of built in or not.
12/10/2014 9:06:52 PM • Bosch Freezers • Answered on Dec 10, 2014
Why doesn't freezer get cold enough
If the thermostat is turned up and the freezer still remains at around 10 degrees I would suggest the system coolant has leaked or the compressor is faulty. Check that the door seals are not obstructed or broken, that will stop the freezer getting colder.
12/10/2014 9:04:10 PM • Bosch Freezers • Answered on Dec 10, 2014
The freezer alarm won't go off.
Possibly a problem with one of the components in the automatic defrost system in the freezer then.. this is the only reason why the alarm would keep sounding. Perhaps some of the moisture from the defrost has gotten in and damaged the electricals somehow. It might be worth it to store your freezer contents elsewhere and completely defrost the freezer and then heat the inside cabinet up with a hair dryer or something similar. This will dry out the cabinet and the electrical components. Once the freezer has warmed up let it stand for as long as possible with the doors open so that it reaches room temperature and then close the doors and switch back on. If this doesn't work you probably need a service engineer visit.
12/10/2014 8:59:26 PM • Bosch Freezers • Answered on Dec 10, 2014
Bosch 9.1 cu. ft. / 258 liter Upright Freezer GSU29424GB Logo
5 questions posted
Top Bosch Freezers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
View Most Popular
Bosch Freezers
  • Bosch Freezers
Most Popular Question
alarm button flashing
  • Freezers
