20 Most Recent
Bosch KGU34641 Bottom Freezer Refrigerator Questions & Answers
Left freezer open for night
You'll need to turn the unit off and leave both doors open for 48 hrs for it to defrost then try it again. cheers
This had never happened before
IN REPLY TO YOUR EMAIL THE FREEZER TEMPERATURE SLOWLY WENT BACK TO 18 DEGREE'S AND HAS STAYED THAT WAY AS IT SHOULD BE I CAN ONLY THINK IT HAD TO WITH THE FREEZING WEATHER AS OUR FRIDGES AND FREEZERS ARE IN A UTILITY ROOM AND CAN GET VERY COLD.
Regards
Patricia
KGU 34641 GB TOP REFRIGERATOR
Hi,I believe you may have a blockage in the intake from the freezer to the fridge as cold air is blown up from the freezer to make the fridge coldhope this helps,mike,
Bosch B26FT50SNS fridge. How to repair broken wire in left ice/water door?
To repair a broken wire in the left ice/water door of the Bosch B26FT50SNS fridge, it is possible to disassemble the left door water/ice dispenser. However, it is important to note that this process can be complicated and should only be attempted by someone with experience in appliance repair.
To begin, unplug the fridge from the power source and remove any items from the door shelves. Locate the screws that hold the dispenser cover in place and remove them using a screwdriver. Carefully pry off the cover and set it aside.
Next, locate the wire that needs to be repaired and determine where it is broken. Cut away any damaged sections of wire and strip the ends of the remaining wires. Twist together the ends of the wire that was cut and use electrical tape or wire nuts to secure them together.
Reassemble the dispenser cover by aligning it with the door and pressing it into place. Replace the screws that hold it in place and tighten them securely.
Finally, plug the fridge back in and test the ice/water dispenser to ensure that it is working properly.
In summary, to repair a broken wire in the left ice/water door of a Bosch B26FT50SNS fridge, you can disassemble the left door water/ice dispenser, locate and repair the broken wire, and reassemble the dispenser cover.
6/21/2023 8:42:28 PM •
Bosch...
Answered
on Jun 21, 2023
