FixYa.com
Bosch HBN 452 / HBN 456 Electric Double Oven
All Products > Bosch > Ovens
Problems with Bosch HBN 452 / HBN 456 Electric Double Oven?
Search inside Bosch HBN 452 / HBN 456 Electric Double... Knowledgebase
Troubleshooting and Support
Solved Problems for Bosch HBN 452 / HBN 456 Electric Double Oven RSS Feed Post a New Problem
Easy Off Heavy Duty Oven Cleaner on Self...
Our maid sprayed Easy Off Heavy Duty Oven Cleaner in our Bosch HBN 456 self cleaning double oven. It has been left...
1 Solution
insallation of gas cooktop in house
need to check if we can put it against the pantry wall we are designing the kithchen thanks heaps
1 Solution
broken oven
display showed fo3 so turned off and back on at mains then there was no power to the oven.
1 Solution
kenmore oven model# 790.79383401 door not...
I just purchased a house that came with a sears kenmore elite duel fuel range. The door does not close with the light...
1 Solution
F9 code on stove
when i turn on oven, all it does is beep and display the F9 code
2 Solutions
smeg oven
hi ..smeg wall oven model sa990x only grill heats up ..fan and light work however only blows out cold air on fan forced
1 Solution
Oven Overheating with Fault Code F1...
Jenn-Air JDS9860AAP Dual-fuel range I have read much about the F1 fault code. Most postings indicate that there should...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Bosch HBN 452 / HBN 456 Electric Double Oven RSS Feed Post a New Problem
Upper Oven Heat Lamp Stay On All The Time
After two years of flawless performance, the upper oven Heat lamp now stays even when the oven is off. What does this...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Self CleaningWith Self Cleaning
Oven FunctionalityBake · Roast · Broil
Oven TypeDouble
Energy SourceElectric
Other Features
Number of Racks5
Cooling FanWith Cooling Fan
Dimensions
Overall Depth22 in.
Overall Height48 in.
Overall Width26.63 in.
Bosch Contact Information
Main support number01895 878093
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
