20 Most Recent
Kohler - Toilet - One-piece - Santa Rosa - K3323-52 Questions & Answers
There is a slow seep of water into the toilet
It's definitely coming through the flapper valve. Look for some interference or crud that prevents the flapper from sealing well. Does it happen intermittently, or constantly? If you can't find the interference try a different style of flapper valve.
good luck.
Al K
What is a flush cylinder
It is really the valve that opens up to let water flow through the bowl when activated by the flush lever, to flush the toilet. it should prohibit water from flowing after the toilet flushes.
The two bolts that holds
a lots of the time when that happens you will need to use a grinder or a ' Dremil ' tool to cut the bolts that are holding down the toilet and get some new bolts and re-install. **** there is also a chance that if you CAN turn the bolt itself from the top that you can get the bottom of the bolt ( which is ' T ' shaped ) to turn in the right direction and get the bolt head to slip through the slots in the floor plate. since you will most likely need new bolts to re-install the toilet, go buy the new bolts at the hardware store and by looking at the bolts and looking at a floor plate at the store -- this will give you a idea of what you are trying to remove.. ( it is kinda like a puzzle ). ******
also --- sometimes you can get a hacksaw blade ( by itself -- not on handle ) to fit between the floor and toilet and cut the bolts that way,, this is kinda a pain to do, but in a pinch it sometimes works good.
I hope these ideas help you --- good luck ( ! ).
c...
Trying to change the toilet
Try using some upward pressure on the bolts while turning them, using a pair of Channel Lock pliers (aka arc-joint pliers). This may stabilize the nuts into which the bolts are threaded. When installing the seat and reinstalling the bolts, a downward pressure may be required into to tighten them properly.
