Bosch Benvenuto B20 Espresso & Coffee Maker
Problems with Bosch Benvenuto B20 Espresso & Coffee Maker?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Bosch Benvenuto B20 Espresso & Coffee...
Troubleshooting and Support
Solved Problems for Bosch Benvenuto B20 Espresso & Coffee Maker RSS Feed
View More Results for Bosch Benvenuto B20 Espresso & Coffee Maker
Questions and Unsolved Support Problems
Unsolved Problems for Bosch Benvenuto B20 Espresso & Coffee Maker RSS Feed
Answer
NOTE: All B20 problems apply to B30 and vice versa - check out the other forum, your solution may be... (More)
Answer
Hello, I have a Bosch Benvenuto B20 (TCA6001) espresso machine, and I have encountered the following... (More)
Answer
Please need servise manual on Bosh benvenuto B20
Answer
I own a Bosch TKN68E75UC Benvenuto Built-In Coffee System, and I'd like to buy cleaning tablets at a... (More)
Answer
I have the same problem. The displays says error 8. Have you already a explanation and a solution... (More)
Answer
Hi! I just want to check if you are able to check where you can find the cleaning tablets for Bosch... (More)
Answer
How do I fix the Bosch B20 when the cup is flashing on the top of the display along with four lower... (More)
Find a Manual
Bosch Benvenuto B20 Espresso & Coffee Maker Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Bosch Benvenuto B20 Espresso & Coffee Maker
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Superautomatic does not make coffee. Wet grounds & pump runs a long...
You have a plugged brew head or bent gate valve. I can help with the brew head but not the gate valve. Remove the brew unit. Holding the handle,... written by bansheracer
Superautomaitc does not make coffee. Dumps wet grounds. Short pump time.
If it pumps for a short time and then dumps the grounds, you either need to reprogram the button. Push and hold the button for the coffee you... written by bansheracer
Superautomatic does not make espresso. Dumps dry grounds
Dosage lever or knob is to the max positive and the brew unit can not compress the coffee, so the machine dumps it into the dredge drawer to prevent... written by bansheracer
No Steam, No Water? Quick Fix
All of a sudden I had no steam and no water. I could hear the pump chugging and trying hard, but nothing came out of the nozzle. First, check to see... written by very-very
Tips for Keeping your Saeco fully functional.
Here's a few Tips for the countless number of people having problems with the Saeco Line Super Automatics Machines. These are more Suggestions if you... written by EspRoastTech
My coffee is weak.
Basing on personal experience (you can find more on Google probably), solutions are: On percolated (filter) coffee machines: Check water temp, if... written by ginko
saeco
descalcified every 3 month the machine will last longer written by pierre235
Keurig B100 Not Brewing Fix
Symptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a... written by Burnzy
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Bosch Benvenuto B20 Espresso & Coffee Maker
Nationwide | 866-240-3413 | Website
When onsite service is not an option you can count on ... Read More
Nationwide | 423-303-3785 | Website
Microwave, blender, mixer parts delivered ove... Read More
Nationwide | 718-584-3449 | Website
Authorized Service center for Saeco, Gaggia, Spi... Read More
Nationwide | | Website
Owner's Manuals and dough kneading paddles for jus... Read More
Ratings for the
Find a Warranty
Specifications for Bosch Benvenuto B20 Espresso & Coffee Maker
Key Features
Type
Espresso Machine, Coffee Maker
Operation Source
Electric
Max. Power
1300 Watts
Max. Pump Pressure
15 Bar
Technical Features
Stainless Steel Body
With Stainless Steel Body
Built-in Grinder
With Built-in Grinder
Cup Warming Surface
With Cup Warming Surface
Water Source
Water Tank Size
.5 oz.
Water Source
Removable
Dimensions
Depth
22.5 in.
Height
16 in.
Width
14 in.
Weight
28 oz.
Bosch Contact Information
Main support number01895 878093
Describe your problem:
Top Coffee and... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
