FixYa.com
Bosch TDA2445 Iron
All Products > Bosch > Irons
Problems with Bosch TDA2445 Iron?
Search inside Bosch TDA2445 Iron Knowledgebase
Troubleshooting and Support
Solved Problems for Bosch TDA2445 Iron RSS Feed Post a New Problem
What if my new Iron has a slight odor?
1 Solution
irons will not heat properly
2 irons, same problem...will not heat sufficiently to press clothes properly. For example, I use spray starch on dress...
1 Solution
Tefal Aquaspeed 160 Steam Iron
Auto Shut off has been activated and i dont know how to reset the iron
1 Solution
wiring diagram
Need the wiring diagram for a ROWENTA DE88-4B
1 Solution
Premature shutting off
Iron works OK for 1 minute, " auto" light flickers and iron cools off. I have Rowenta mod. # DG...
1 Solution
Why isn't my Iron heating up?
Why isn't my Iron heating up? Just finished filling my Krups V65 iron with water. Was ironing linen shirt on linen...
1 Solution
Faulty Steam Iron GC4420
Doesn't hold heat, switches off & on all the time reducing heat.
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Bosch TDA2445 Iron RSS Feed Post a New Problem
will not switch on
our bosch iron will not switch on. have checked the plugs fuse which is ok. we think it may have been left switched on....
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Cord TypeCorded
Vertical SteamingWith Vertical Steaming
Adjustable SteamWith Adjustable Steam
Other Features
Spray MistWith Spray Mist
Auto Shut-OffWith Auto Shut-Off
Self-CleaningSelf-Cleaning
Water Capacity7.6 oz
Power
Wattage1500 Watts
Bosch Contact Information
Main support number01895 878093
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
