20 Most Recent MakerBot Replicator 2 Desktop 3D Printer Questions & Answers
3answers
Any idea about 3d printers parts suppliers?
It would more better to answer if you add your shop location. Whatever, you can contact with a good supplier who can provide you all the parts easily to you.Before ordering you should ask the supplier about sending time,price for bulk and and warranty,because its help you to support your shop customers. i know a 3D Printer parts supplier ,you should try,they are supply through amazon.
8/4/2022 10:51:02 PM • MakerBot... • Answered on Aug 04, 2022
2answers
Clogged Extruder head
It is not unusual for the extruder to get clogged, especially when changing filament. the problem occurs when pulling the hot filament out and a tail forms within the filament channel. you can remove the stepper motor and try and pull the filament out. also unscrew the extruder tip and see if it will pull the clog out with it. I use boiling water to clear the extruder head and it works nicely. if it is stuck in the filament tube you may need to pull the filament tube also to clear it out. it is also possible to remove the stepper motor and heat the extruder on preheat and push the tail inside the tube. once this is done you should be able to "Load Filament" normally and once the new color id extruding your good to go.
2/5/2018 7:06:48 AM • MakerBot... • Answered on Feb 05, 2018
Need mightyboard motherboard
Here is a link to buy a replacement motherboard, in case you haven't already purchased one. It is from the manufacturer. You can get it with or without the power supply. MightyBoard Power supply As for installation, here is a handy youtube video that explains the installation process of the makerbot mightyboard. Replacing the MakerBot Replicator Mightyboard I hope these links help you with your 3D printer!! Best of luck!
4/7/2014 2:35:26 PM • MakerBot... • Answered on Apr 07, 2014
0answers
Not load filament
Be the first to answer 5/13/2013 1:38:06 PM • MakerBot... • Posted on May 13, 2013Be the first to answer
4answers
How many ounces of body lotion is 200 ML ?
200 ml is about 6.76 US ounces or about 7.04 UK ounces.
4/24/2024 8:53:54 PM • Office Equipment... • Answered 11 hours ago
How do these points equate to money?
No money ever! There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun. ADMIN Andrew
  • Answers: 65,820 and not a penny per Answer.
Head over to www.justanswer.com they pay lots of money because they charge for people to ask a question. ..
4/19/2024 9:45:02 PM • Office Equipment... • Answered on Apr 19, 2024
Error code e000350-0002
'Make model (what it is)' is needed in questions like this, and in fact ALL questions!! But we can just guess.
Error Code Ir 3300 e350-3000 and e350-00002
Copytechnet https://www.copytechnet.com > ... > Canon May 1, 2018 - Put ALL the original boards back in the machine. Go to service mode level 2 & perform E355 clear. If this fails your machine is scrap. CANON iR2200 Error code E000350-001 Jan 22, 2007 error code :E0003-0002 canon IR 2880i Feb 5, 2018 Canon IRA C5540I Code E000354-0002 Sep 23, 2021 E000350-3000 on IRC4580 Sep 25, 2017 More results from www.copytechnet.com
Canon iR Advance 4245 - E350-0002
PrintCopy .info https://printcopy.info > code=E350-0002 Canon iR Advance 4245 ; Code: E350-0002 ; Description: System error ; Remedy: Contact to the sales companies. ..
4/19/2024 5:37:38 PM • Office Equipment... • Answered on Apr 19, 2024
E6 on my ISMART 500 trojan. How do i fix it please
This link is the best I can come up with: How to fix E6 & E7 on Trojan treadmill solved!! (youtube.com)
4/19/2024 12:27:09 AM • Office Equipment... • Answered on Apr 19, 2024
2answers
Error code Z08-1090
I need help I have an error on my ComColor 7050 Z08-1090
4/18/2024 11:40:08 AM • Office Equipment... • Answered on Apr 18, 2024
2answers
How do I fix this error SEr on conlog prepaid meter
Call your supply company.
4/17/2024 1:47:07 PM • Office Equipment... • Answered on Apr 17, 2024
Setting tax rate on Ativa KC-421
How to set up tax rate on Ativan 12 digit calculator
4/16/2024 1:16:37 AM • Office Equipment... • Answered on Apr 16, 2024
2answers
Tech solutions mod# TS8000 lost power while shedding
You posted to the Category 'Cars and Trucks'? shedding? Help in the link https://www.google.com/search?q=Tech+solutions+mod%23+TS8000 All questions need 'make model (what is is)' as first 3 words. Thinking that this might be a 'shredder' gives better results, we also have a Shredder Category, so I moved it. Shredders have an overheat thermal cut out and also a thermal fuse. It may reset itself. https://www.google.com/search?q=Tech+Solutions+TS8000+shredding+no+power ..
4/14/2024 7:19:19 PM • Office Equipment... • Answered on Apr 14, 2024
2answers
Tech Solutions TS8000 Shredder. Suddenly no power on mod TS8000
Edited for clarity. Full 'make model (what is is )' please first 3 words. Thermal cut out, thermal fuse, or burned out motor. They all have a suggested time limit for running them and is generally 20 minutes unless it is a commercial model and cost $1,200 to $4,000. https://www.google.com/search?q=Tech+Solutions+TS8000+shredding+no+power It looks to be a capable machine, but no parts from 'Shredder Parts dot com'. https://www.google.com/search?q=Tech+Solutions+TS8000 ..
4/14/2024 7:17:27 PM • Office Equipment... • Answered on Apr 14, 2024
Can you help me with code for mega power tv
Try "supervisor" as the username (no password).
4/14/2024 7:07:36 PM • Office Equipment... • Answered on Apr 14, 2024
3answers
I'm looking for a permanent job what can I do?
You should write good resume and then to search vacancies on job boards.
4/10/2024 2:36:35 AM • Office Equipment... • Answered on Apr 10, 2024
Canon imageCLASS MF3010 Black & White Multifunction Printer. How do I fix Error E2 please?
Question edited for clarity.
Canon imageCLASS MF3010 - Error Codes
PrintCopy .info https://printcopy.info > model=imageCLASS+MF3010 Error Codes List page 1 · Code: E000 · Description: Startup failure · Remedy: (1) Check the connectors of the Fixing Assembly. (J101, J1011, J552 and J702) (2) ... ..
4/6/2024 1:10:35 AM • Office Equipment... • Answered on Apr 06, 2024
How can i reset my sc553?
how to remove error code sc553-00 from my uninet 800
4/1/2024 11:25:06 AM • Office Equipment... • Answered on Apr 01, 2024
4answers
RE: Vibe USB Turntable Model:
your choice of "Vibe" turntable could have not been worse.
Any serious Vinyl collector would not use such a cheap piece of equipment.
You Get What You Pay For is so very true in this case.
3/30/2024 11:17:37 PM • Office Equipment... • Answered on Mar 30, 2024
Riso EZ 370E freezes abruptly while printing. How to fix please?
No one in North America has Risograph machines. Try this link https://www.google.com/search?q=Riso+EZ+370E+freezes+abruptly+while+printing ..
3/30/2024 9:05:56 PM • Office Equipment... • Answered on Mar 30, 2024
MakerBot Replicator 2 Desktop 3D Printer Logo
4 questions posted
Top MakerBot Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a MakerBot Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • MakerBot Office Equipment & Supplies
Most Popular Question
any idea about 3d printers parts
  • Office Equipment & Supplies
