20 Most Recent
LG Tone HBS-730 Bluetooth Headset- Black Questions & Answers
Volume in left earbud is suddenly very low
just do the volume the equalization. Once the Bluetooth is on just click the volume (+) until you hear a beep then click volume (-) until you hear a beep, this should equalize your volume. and give you equal sound from both of you earbud.
Factory reset
My lg hbs 730 is problem a pair nem changed va9625 pairing and connected volume key is not working not call and any other key only power on/off working plz I want factory rest help me
My LG HBS730 is conected to my PC but don't I don't hear anything
You have to make sure your pc is using the correct bluetooth profile. It may only be connecting as a headset for talking. You need to make sure it's set up to connect for audio playback as well. If you're using windows, you can change the settings in your device manager.
What causes my HBS-730 to keep redailing calls
If it's under warranty, take it back. The call button is either stuck or has moisture in it. If you're good with with electronics you can open it up and inspect the buttons. You can also pick up a broken one on ebay for parts.
Lg tone 730 too loud
Here is a solution: Remove rubber ear buds from the device. take a breathable band-aid package. Use two layers of band-aid cut into very small circles..stick the 2-ply band-aid circle to the headphone. Replace the rubber ear bud. This will reduce the sound sufficient to carry on!!
On LG tone infinim hbs900 I have a blinking blue light but won't pair to my Apple iPad ?
If the LG Tone Infinim HBS900 is not pairing with your Apple iPad, there are a few things you can try to troubleshoot the issue:
- Check the Bluetooth settings: Make sure that Bluetooth is turned on and that the LG Tone Infinim HBS900 is in pairing mode. To put the device in pairing mode, press and hold the power button until the LED light flashes blue and red.
- Check for software updates: Make sure that your iPad has the latest software updates installed.
- Check for other connected devices: Make sure that the LG Tone Infinim HBS900 is not already connected to another device. If it is, disconnect it from that device before trying to connect it to the iPad.
- Check the distance: Make sure that the LG Tone Infinim HBS900 and the iPad are within close proximity to each other. Bluetooth devices typically have a range of around 30 feet.
- Reset the LG Tone Infinim HBS900: Hold down the power button for 10 seconds, release, and then hold it down again for another 10 seconds.
- Reset the iPad's network settings: Go to Settings > General > Reset > Reset Network Settings.
- Check if the device is in pairing mode, if not activate it.
If none of the above steps resolve the issue, you may need to contact the manufacturer or a professional technician for further assistance. It's recommended to check the user manual of your device before trying any of the above steps, as the process of troubleshooting the pairing process can vary depending on the model and manufacturer.
1/28/2023 12:39:52 AM •
LG Radio...
Answered
on Jan 28, 2023
