20 Most Recent BT Response 75 Plus Answering Machine Telephones Questions & Answers
Can you record your own message on a bt response 75
Hi Your BT response 75 has 2 built in responses depending upon whether it is set to Ansaphone or Answer only. How to do it is all clearly described in the manual which can be downloaded from here: http://btsupport.custhelp.com/ci/fattach/get/388827/1219393992/redirect/1/session/L2F2LzEvdGltZS8xNDE5OTM1MzY5L3NpZC96Ymt6X2FibQ== and saved to your computer for future reference. It is in pdf format and can be read using Adobe Acrobat Reader. The page you require for reading about the outgoing message is p11 of he manual, which is p13 of the pdf file. Hope this is helpful, if so would you please register that with Fixya Cheers
12/30/2014 10:35:37 AM • BT Response 75... • Answered on Dec 30, 2014
0answers
How to clear the memory rom a BT 4500 Base set
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi-nrXtxJSCAxUBrYkEHZZkBXUQFnoECBUQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft25573321-delete_full_memory_bt_4500_cordless&usg=AOvVaw2R7gqbfiZjt7mTjdIDw08Z&opi=89978449
10/26/2023 8:20:47 PM • BT Lands Phones • Answered on Oct 26, 2023
OUR BT HANDSET SAYS THE LINE IS BUSY WHEN IT'S NOT. i HAVE RESET THE HANDSET USING THEINSTRUCTIONS ON LINE FOR THE BT ASPIRE
The busy signal message only indicates that the phone doesn't get a dial tone signal. This could result from a problem with the wires inside or outside the home. With some modern fiber optic systems, the modem that translates the signal back to POTS (plain old telephone system) analog could be faulty. I like to use an old corded basic phone for most diagnostics. First, try a new RJ-11 cord between the phone base and the jack. (I've seen someone use the coiled handset cord between the phone and the jack. That doesn't work.) If the new cord works, great. Otherwise, test with another phone. If the test phone has a dial tone, then the problem is with the BT system. For cordless phones, double check if the unit is getting power. Transformer bricks should get warm. If it is under warranty, contact the company. If you still don't have a dial tone, test the phone line at another jack for that number, if one is available. If other jacks work, then you have a problem with that jack or the wiring back to the incoming service. Most phone jack faceplates either secure the wires with screws or a keystone. For the first, you will need to strip the wires before securing them to the appropriate point. For the second type, you don't strip the wires. Instead you need a punch-down tool (available at most hardware stores in the low-voltage wiring section). Use https://www.lanshack.com/wire_phone_jack.aspx for the correct wire placement. If you recently had someone work on the service connection, check if all of the extension wires were connected to the correct part of the service box. If the problem isn't specific to one jack, check your incoming service box. In some cases, you can just plug in the basic phone's RJ-11 cable and listen for a dial tone. If there is no dial tone, contact your telephone company. Somewhere upstream, there is a damaged wire. For underground copper telephone wiring, the problem could be from animals chewing on the wires or someone damaging the wires while digging. Most companies should fix outside problems for free. Some will try to sell you a service upgrade instead. If you can't test the service at the box, contact the telephone company. They have the equipment to test the line. These technicians can also fix inside wiring problems for a fee. I hope this helps. Cindy Wells (Yes, I have dealt with these problems before. The service upgrade was the strangest one. They unplugged four extension wires at the start of the job. Then they lost one wire behind the siding when they finished. It took three minutes for me to find the wire and plug it back into the service box with RJ-11 jacks.)
8/24/2022 11:33:41 PM • BT Lands Phones • Answered on Aug 24, 2022
I connected a call blocker to a BT duet 600 phone and the ringer red light always stays on?
then take it back off the system
10/20/2021 7:58:07 PM • BT Lands Phones • Answered on Oct 20, 2021
BT 4.0 instruction. Manual
If you are meaning the home hub 4 router, here is link to all BT routers user guides http://bt.custhelp.com/app/answers/detail/a_id/10477/~/user-guides-and-manuals-for-bt-hubs
8/22/2019 3:53:09 PM • BT Lands Phones • Answered on Aug 22, 2019
How do i stop flashing red light on bt paragon
Here is a link to the full user guide, https://btsupport.custhelp.com/cgi-bin/btsupport.cfg/php/enduser/cci/bt_adp.php?p_sid=&cat_lvl1=1818&p_cv=1.1818&p_cats=1818&p_faqid=11244 red light flashing indicated that you have had an incoming call
8/22/2019 3:37:21 PM • BT Lands Phones • Answered on Aug 22, 2019
Handset set says power up bs .phone model bt 1700
BS I assume is the Base Station is not active.
10/9/2018 12:17:14 AM • BT Lands Phones • Answered on Oct 09, 2018
BT Response 75 Plus Answering Machine Telephones Logo
3 questions posted
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
Jesse Walters
Jesse Walters
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
BT Lands Phones
  • BT Lands Phones
Most Popular Question
record own message bt response 75
  • Lands Phones
