20 Most Recent Makita Gd0600 Die Grinder Questions & Answers
the brushes are most likely worn out. Its a quick fix, but need to contact Makita for the right parts
Makita Gd0600... | Answered on Mar 06, 2011
Could be quite a few things from something in the fan to a coupler that is splitting apart. I would recommend going to Makitatools.com and typing in your model number and downloading a breakdown if you are going to fix this yourself. Let me know if I can help, it has been awhile since I worked on one of these.
Makita Gd0600... | Answered on Feb 25, 2009
One turn.
Grinders | Answered on Mar 05, 2019
Find a Single Pole Single Throw (spst) toggle switch at the local hardware store rated for the load of the grinder. Wire the switch in place and viola you are done! Machines are stupid;they can tell the difference between an oem part and a replacement.
Grinders | Answered on Jul 11, 2018
You can get a replacement toggle switch at any hardware store look in the electrical department.
I cleaned all the wiring connectors etc and used a 4-way extension cord with an i/o switch and thermal/arc breaker surge protector thingy. I had a piece of thick cable with a molded three prong plug which I had removed from a dead paper shredder (I think??) and connected the ground to the case (previously not connected) the black to the black and white to the white. I taped the connections and plugged the test cable into the extension thingy with its switch off and plugged it into the wall outlet. Then, with the grinder switch on, I gingerly switched on the extension thingy and the grinder (sans all moving parts) ie just the motor case and spindle (held securely in the B&D workmate) and viola(!) it worked fine and built up to very fast. I switched off the grinder switch and the motor slowed, taking an age to come to rest.
Then, I fitted a grinding wheel on the left hand thread end, tightened everything and retested, using the grinder switch to start it and it spun really fast.
Soooo, I guess the secure ground is an essential feature of a capacitor induction motor. I checked some old furnace motors that were "maturing" in the basement and they had no capacitor but only 2 wires...
I am now trying to remember which parts came off last and put it all back together. I plan to test it each time I put a part back...just in case. I hate it when you fix something on the bench and when rebuilt, it won't work...don't ask about the electric starter on the snowblower..not a happy puppy!
Please, pretty please and then some, do tell me if my "fix" is wrong and I could risk all kinds of nastiness.
Thanks,
Jenni.
Grinders | Answered on Jun 13, 2018
Jet 577102 is a bench grinder with 1HP motor. It has got guards on the grinding wheel. Dust vents and guard makes the grinder makes it an efficient grinder. 115 Volt is needed to run this high performance grinder.
Grinders | Answered on Jun 09, 2018
Sometimes it could be like this contact by the centrifugal interrupter or the powerswitch or startcapacitor (only if its buzzing) an other kind of relay switch it should be simple to measure it .but to adjust it for time release can be ??.
Grinders | Answered on Mar 12, 2018
To convert it its possible more expensive then buy an other grinder but there is some trick to connect in serial on the powercord a light bulb on a special choosen ability differs on the RPM or use a variable power resistor also in serial connection between on one of the 2 wires on the powercord.
Grinders | Answered on Feb 28, 2018
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Grinders | Answered on Jul 04, 2017
    Makita Gd0600 Die Grinder Logo
    5 questions posted
    Top Makita Grinders Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Vernon Taylor
    Tom Chichester
    Are you a Makita Grinder Expert? Answer questions, earn points and help others
    View Most Popular
    Makita Grinders
    • Makita Grinders
    Most Popular Question
    loud noise coming from above paddle
    • Grinders
