20 Most Recent
Karcher G3025OH Pressure Washer Questions & Answers
Karcher 3000 psi won't start.
It sounds more like a carb problem flooding and dumping some gas into the oil. This unit probably has a low oil sensor and the gas could be affecting this. I would have somebody look at the carb and find out why doing this, change the oil and try again. I have one that leaks gas because of float problems, that has done it since new, waiting for spring to remedy. Good luck, Also you can go to Karcher.com for a parts explosion and manual if needed.
The engine starts cold after 2 or three pulls,
I would first try draining the carb bowl, if you look at where the choke lever is and look below that you should see a clear red tube with a flat head screw below that, if you just turn the screw out the carb will drain. If you still have an issue you are going to have to clean the carb.
Wont start acts like no spark but is getting spark
Did you try pulling the spark plug and spraying some starter fluid or carb cleaner into the cylinder, putting the spark plug back in and starting it? If you've got spark and it doesn't start for a few seconds then you probably have carb problems. Good luck!
No pressure / Karcher G 2400 HH
Hi ruthkapres:
Here is a diagram. The unloader/spill valve is #12 on page D2 or F2 depending on your model. You must pull it out, inspect the o-rings for dents or tears and make sure the valve is lubricated with a good water proof lubricant.
