20 Most Recent
Sharp 52"" aquos lc-52sb55u 1080p widescreen lcd hdtv - 16:9 10000:1 Questions & Answers
Trying to connect pc with hdmi cable have great picture no sound on TV Used HDMI imput 7 tried imput 6 with hdmi and audio imput from PCF to TV still picture and no sound any suggestions
Hi Scott,
On your PC, you'll need to go into the Control Panel --> Hardware & Sound --> Sound (Windows 7) and click on "Playback". Here, you'll need to change the sound settings to reflect the audio to be handled by the video card / audio chipset / HDMI jack on the motherboard. You should also check for other settings such as Digital Output that are usually associated with and HDMI jack on the card and not an analog jack.
As it is now (or is likely to be the case anyway) the picture is being handled by the HDMI on the video card / motherboard; but the audio is still coming from the the speaker jack(s) on the motherboard or audio card. Making the changes above will redirect the audio from the speaker jack(s) to the HDMI jack instead.
Sharp TV LC60LE745U the screen remained black and an arrow on the bottom of the TV stay blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
I have no sound on my sharp aquos 60" TV.
We have the same TV. In settings for sound you need to select the port directing where you want sound to play. It may be that it is currently setup to play to a sound bar.
