Continental CE-PAC1163 Castle Series 11000 BTU Digital/Remote Control Portable Air Conditioner P...
Problems with Continental CE-PAC1163 Castle Series 11000 BTU...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Continental CE-PAC1163 Castle Series...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Continental CE-PAC1163 Castle Series 11000 BTU Digital/Remote Control Portable Air Conditioner P... RSS Feed
View More Results for Continental CE-PAC1163 Castle Series 11000 BTU Digital/Remote Control Portable Air Conditioner P...
Questions and Unsolved Support Problems
Unsolved Problems for Continental CE-PAC1163 Castle Series 11000 BTU Digital/Remote Control Portable Air Conditioner P... RSS Feed
Answer
I have a continental A/C ce-pac13631. Somehow one of my daughters changed the read out to celcius... (More)
Find a Manual
Continental CE-PAC1163 Castle Series 11000 BTU Digital/Remote Control Portable Air Conditioner P... Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
COMPRESSOR check outs semplified.
If your wondering how to check out your refrigeration compressor; Modern Compressors have two operations that have to work together just to run.... written by farfield
Air Filter changing - easey and often
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date... written by farfield
AC DRAINAGE PIPING REQUIREMENT
Slide 71 .O {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC... written by bobotfel
HOW TO CHECK A GOOD REMOTE CONTROL
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and... written by bobotfel
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for CE-PAC1163 Castle Series 11000 BTU Digital/Remote Control Portable Air Conditioner P...
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Rate and Review the Continental CE-PAC1163 Castle Series 11000 BTU Digital/Remote...
Write a review:
Rate this product:
Would you recommend the CE-PAC1163 Castle Series 11000 BTU Digital/Remote Control Portable Air Conditioner P... to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Continental Contact Information
Main support number1-866-915-1212
Email supportcustomerservice@cemglobal.com
Describe your problem:
Top Air Conditioners Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
