20 Most Recent Denon AVR2313 7.2 Channel A/V Receiver Questions & Answers
There is no module per se. Tuning is accomplished by applying a voltage to the tuner chip and their associated circuits. It needs to be repaired by a Denon service center.
Denon AVR2313... | Answered on Oct 25, 2016
Hi Ray Lynam, for what you say, you could have a problem with the speaker output
I suggest you remove the cover and look for two F2 and F3 fuses of 4Amp each that correspond to the output of the speakers, check if they are burned, if so replace them, ONLY FOR FUSES OF EQUAL VALUE 4AMP, do not put more value because you could produce major damage, test the equipment and if they burn again, then if you have problems at the exit stage
In this case, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Ray Lynam, por lo que comentas, podr?as tener problema en la salida de parlantes
Te sugiero retirar la tapa y buscar dos fusibles F2 y F3 de 4 Amp cada uno que corresponden a la salida de parlantes, controla si est?n quemados, si es asi reemplazalos, SOLO POR FUSIBLES DE IGUAL VALOR 4 AMP, no pongas de mayor valor porque podr?as producir un da?o mayor, prueba el equipo y si se vuelven a quemar, entonces si tiene problemas en la etapa de salida
En este caso busca un servicio t?cnico especializado
Espero que puedas resolver el problema
Saludos Franco Dosil
https://www.hifiengine.com/manual_library/denon/dra-350.shtml
Denon Audio... | Answered Yesterday
I would guess it's the Surround Sound mode button. Various modes in Surround Sound do not use all 5 speakers. Often the button pressed repeatedly changes between the modes. So if you press it again it might restore the sound mode to the one you had. I can't be more specific as you did not give the model number.
You could try the Denon website to see if they have a free PDF of the user manual, if you have lost it. You will need the model number for that though.
Denon Audio... | Answered on Jul 22, 2019
Try unplugging it. Another thing is some units have a fuse in the back. Check the fuse with a multimeter for continuity. If meter shows OL then replace the fuse.
Denon Audio... | Answered on Jul 15, 2019
(1)Download AVR3310 service manual.
(2)enter debug mode to see what kind of protect it belongs to.
(3)DC or ASO protect
(4)DC protect to check all smd transistors if leakage occurs or
differential and voltage amp transistors leakage
(5)ASO see service nanual troubleshooting steps.
(6)Replace all defective components.
Denon Audio... | Answered on Jun 24, 2019
You can buy any Denon av-amp remote to control your av-amp.
Denon Audio... | Answered on Jun 21, 2019
Hello Terry, your Denon AVR 2808, is not compatible with HDMI 4K signals, only for HDMI type 1.3, HD signals
You can use your TV to connect all HDMI 4K sources and send a fiber optic connection from the TV to the Denon to get the sound of the equipment connected to the TV
Hola Terry, tu Denon AVR 2808, no es compatible con se?ales HDMI 4K, solamente para se?ales HDMI tipo 1.3, HD
Puedes usar tu TV para conectar todas las fuentes HDMI 4K y envias una conexion de fibra optica desde el TV, hacia el Denon para obtener el sonido de los equipos conectados en el televisor
https://www.denon.es/es/product/hometheater/avreceivers/avr2808 https://www.denon.co.uk/uk/product/hometheater/avreceivers/avr2808 https://ca.denon.com/ca/product/hometheater/receivers/avr2808ci?docname=avr-2808ci-om-e_102.pdf
Denon Audio... | Answered on Jun 13, 2019
Reset the amp to factory default may solve your problem. Download service AVR2312 to see how to do.
Denon Audio... | Answered on Jun 12, 2019
Hi Gordon, the wireless headphones, has a transmitter that is connected to the VCR 1 or VCR 2 outputs, or to the output of PreOut Front L R, in this case the sound level a to be modified by the general volume control of the Denon
I hope you can connect and enjoy your headphones
I sent you a link to download the user manual of your Denon, there on page 9 you will see the connections that I tell you
Hola Gordon, los auriculares inalambricos, tiene un transmisor que va conectado en las salidas VCR 1 o VCR 2, o a la salida de PreOut Front L R, en este caso el nivel de sonido a a estar modificado por el control de volumen general del Denon
Espero puedas conectar y disfrutar de tus auriculares
Te env?o un link para que descargues el manual de usuario de tu Denon, ah? en la pagina 9 veras las conexiones que te comento
https://data2.manualslib.com/pdf/4/383/38281-denon/avr1802882.pdf?b0cdee2d6d49fc2300788aa73a04efc3&take=binary
http://www.manualsbase.com/es/manual/downloadmanual/172578
Any power amps able to connect to pre-out can be used and of course, choosing a power amp with large rating is better.
Denon Audio... | Answered on Jun 09, 2019
" "I have seen a manual I which it said that dc issue, do anyone know how to disable the power on fault checking" You cannot do this. Protection can only be kicked out when no dc is coming out from speaker terminals. This holds no mater whether differential and voltage amp are defected (leakage) or protect detection SMD transistor(s) is/are leaked. They act as a switch. Download X2100W service manual and enter debug mode to check if DC or ASO(over-current protect ) makes protect.
Denon Audio... | Answered on May 29, 2019
“My reomote sensor is not lit and I have no sound coming from speakers” For your symptom, not related to remote sensor but to digital decode board such as DIR,DSP and LPF. Download service manual and enter "debug mode" to locate defective circuit(s).
Denon Audio... | Answered on May 27, 2019
Denon AVR2313 7.2 Channel A/V Receiver Logo
1 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
denon avr 2313ci receiver fm tuner quit
  • Audio Players & Recorders
