20 Most Recent
Iwill VD133Pro Motherboard Questions & Answers
Won't boot after installing PCI wireless adapter
Dear sir
good day
if you face such problem that means that the
first boot device is the wireless NIC itself
so go and enter the setup bios program and
then change the option to boot from hdd
thanks
Windows log on problem
well under windows 2000/xp ctrl+alt+del is not the key to restart ur pc it was in windows 98 n windows me but now they'ave removed this option from it so u cant restart it by keys just go to start select shutdown n den select restart!
Front panel pin layout. I need the front panel pin layout especially for the HD IDE active LED.
Howzit
Trial n Error is your best bet on the control pins panel there are two rows, with the power plugged in,with a screwdriver touch adjacent two pins together at a time starting with the top row then the bottom row, when you touch the right two pins your motherboard will power-up, then place the power-switch plug onto those two pins (the writing on the plug facing innwards toward the mainboard) the two pins for the reset switch and 99.9% of the time located directly next to the power switch or directly above the the power pins on the other row. For the LED lights you will have to just try the different pins and the Power LED will remain on as long as your mboard is on, but to find the LED pins for the Harddrive you will have to plug in your HDD and then when it powers up try the pins and the led for the HDD will flicker on-off, that would be the correct one. Dont worry your mboard will not be damaged by this in any way. Goodluck and let me know how you go. Thanks
Regards
Norton tells me that my
yes you can i need to know how much ram yyou have and what windows you have also then i will give you the price of how much the ram will be and give you a link to where you can buy it and then instruct you on how to fit it if this helped be sure to vote i look forward to hearing how you got on please reply with the details
Hello, first of all I need know where the serial
Serial nos of mother board is located in near the ram slot.
Check the ON button if your pc not ON.
check where the jack pin of power button is inserted in motherboard pull it out and short that both pin using wire(touch ones), if again computer not ON then check your SMPS power supply, if again PC not ON then it means your motherboard need repairs no matter the light is ON or NOT.
if u get power light then wire formula will work. Good Luck
