20 Most Recent
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Questions & Answers
Furnace won't stay lit
Are your air filters relatively new? Is a bird nesting in your units combustion air exhaust pipe? Does your draft inducer motor run before and after the gas has ignited? Check and confirm these 3 things first. Good Luck!
The draft inducer comes on and the furnace lites
When a furnace is replaced with a newer style unit like yours with an inducer motor, they sometimes use the old vent pipe. These old style vent pipes are transite (light weight cement), the moisture created from your furnace exhaust is caught on the cool transite surface and runs back down into the blower blades or wheel bringing a white mineral deposit with it which causes your problem. The vent should nave been replaced with the heater using a metal vent material. You will need to replace your inducer motor assembly and vent pipe to prevent a recurrence.
I have XE 80 install
Hi. First of all, let's talk about why a fuse blows. The short answer is heat from an overloaded electrical circuit, but there's more to it than that. That blown fuse may have saved the rest of your house from burning down.
That said, the fact that the fuse blew and the motor seems to have failed goes hand in hand. I recommend taking the unit apart so that the fan's rotation and the fan's motor can both be checked over.. I suspect that you will have to replace the motor, common on a 20 year olf appliance. J.
When the furnace comes on after recovering from
Could be correct, or you may have something in your fan that either fell into or crawled into your fan through the exahust duct.Since you have a service contract, have they actually been out to look at it or did they tell you that on the phone. It might be worth removing the fan and clear any forign matter. The problem is the labor to do that would be the same as to replace it. What does your service contract cover??
