20 Most Recent
Powermatic 1352001 3520B 20x35" Wood Turning Lathe Questions & Answers
Where are the gears ?
I see no gears in the manual You can move the belt over to get a different speed if that is what you are asking.
http://content.wmhtoolgroup.com/assets/manuals/1352001_man_EN.pdf
The hand wheel on the tailstock is getting harder
Take the entire screw out of the tailstock and examine the internal and screw threads carefully. Suspect something is 'galling' the threads causing the bind or possibly, the screw has been bent. You may have to chase the threads with a suitable tap and die to get things working again. It may also be that the lubrication did not reach the entire thread. Hope this helps!
Looking for info/ manual for a wool lathe
look under cwl12d clarke wood lathe manual. this has all the instructions that are almost the same as the nwl37-2 i have a nwl37-2 and this manual shows what should be there.
