20 Most Recent Cuisinart BFP-703 SmartPower Work Top Blender Questions & Answers
Here is a list of things to check for:
1. Make sure the blender base (black plastic) is tight to the jar.
2. Make sure you have installed the rubber washer between the blender blade assembly and the jar.
3. Make sure your rubber washer is free from any crud that may have accumulated and dried on. You may have to soak the washer and gently scrub with a scrubber sponge. If it's really cruddy you may have to repeat as necessary.
4. Make sure you have not caught any water (or other liquid) when filling it between the base and the jar. When you pour out the contents it will appear as if it is leaking.
Cuisinart... | Answered on Oct 12, 2017
The Instruction Booklet for your Cuisinart BFP-703 SmartPower Work Top Blender can be found here:
http://www.cuisinart.ca/pdf/ibs/en/BFP-703CHC_en.pdf
Thank you for using FixYa!
Cuisinart... | Answered on Aug 13, 2011
The motor most likely burnt out. Happened to mine to.
Cuisinart... | Answered on Jul 02, 2009
The blade assembly is not being locked onto the base of the container. Check the instructions for the correct procedure.
Cuisinart... | Answered on Mar 21, 2019
At least on Amazon, the customer reviews are not so good ... only a 3.1 out of 5 for 38 reviews. Some of the poor ratings are that the unit just stopped working or a plastic housing part broke. You may have blown the motor. If it is still under warranty, and you have the receipt, you might consider shipping it back to Cuisinart ... but you pay for the shipping
Cuisinart... | Answered on Feb 19, 2019
If the power light is on and the motor is not running the circuit board that starts the motor is defective. You could try to bypass the control board and apply power directly to the motor to verify the motor is ok and no blown fuse or circuit breaker. then you get to replace the circuit board or isolate a failing component on the circuit board.
Cuisinart... | Answered on Jan 01, 2018
here ya go.!! http://www.1800parts.com/product.asp?pid=16377&sid=18954&mid=8&gid=18957&******=Brand
Cuisinart... | Answered on Oct 30, 2017
Cuisinart DLC 1 Mini Prep Processor Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Cuisinart... | Answered on Sep 03, 2017
Cuisinart BFP-703 SmartPower Work Top Blender Logo
7 questions posted
Top Cuisinart Blenders Experts
eyecam
Gil Shultz
ray gallant
ray gallant
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
View Most Popular
Cuisinart Blenders
  • Cuisinart Blenders
Most Popular Question
manual destroyed need new
  • Blenders
