20 Most Recent
Ingersoll Rand 1? Heavy-Duty Air Impact Wrench # 295A Questions & Answers
Missing parts
The rebuild kit #295A-TK2 has all the parts to bebuild your existing model. The includes a new plunger and spring plus all seals and vanes for this model. Any IR dealer can get this for you.
LOW SUMP PRESSURE SHUT DOWN
more info would help but if it is shutting down because of "low oil" then you can do one of two things but first make sure the oil is at the proper level
unplug the low oil safety switch...
fix it correctly
next time, let us know what kind of engine you have and model numbers of everything involved
VSD Fault 23
Vsd 23 is a motor under speed problem. Check motor turnes ok, if not it could be a number if faults including the hall effect sensor that detect motor speed, you will need to call a Ingersoll Rand technicion in to do a 348 diagnostic test.
Start run capacitors wiring diagram for Ingersoll Rand T30 5HP
In a typical setup, start and run capacitors are not wired directly to each other. They serve different purposes in the motor circuit. Start capacitors are used to provide an extra boost of power to start the motor, while run capacitors help improve motor efficiency and performance during operation.
Here is a general wiring guideline for start and run capacitors:
- Start Capacitor: The start capacitor is usually connected in series with the motor's start winding. It helps provide an extra boost of power during motor startup. The wiring configuration typically involves connecting one lead of the start capacitor to the start winding, and the other lead to the common terminal or neutral connection.
- Run Capacitor: The run capacitor is typically connected in parallel with the motor's run winding. It helps improve motor efficiency and performance during operation. The wiring configuration usually involves connecting one lead of the run capacitor to the run winding, and the other lead to the common terminal or neutral connection.
It's important to consult the manufacturer's documentation, wiring diagram, or a qualified technician familiar with the specific model of your Ingersoll Rand T30 5HP compressor for the accurate wiring instructions. They will have the expertise to provide you with the precise wiring configuration and any specific considerations for your particular compressor model.
If you're unsure or uncomfortable with the wiring process, it's recommended to seek professional assistance from a qualified electrician or a technician experienced with motor wiring and compressor systems. They can ensure the wiring is done correctly and safely.
Master reset / Service complete for Ingersoll Rand Intellisys Nirvana v2.63 VFD controller
Performing a master reset or service complete on an Ingersoll Rand Intellisys Nirvana v2.63 VFD controller typically requires a specific code, which may only be provided by an authorized Ingersoll Rand technician or service center. However, you can try the following steps as a workaround:
- Press the "ESC" button to enter the main menu.
- Use the arrow keys to navigate to the "Utilities" option and press "Enter".
- Navigate to the "Service Complete" option and press "Enter".
- Follow the on-screen prompts to enter any required information and confirm the service complete process.
- If the alarm continues to go off after attempting the service complete process, you may need to contact Ingersoll Rand or a qualified technician for further assistance.
It is important to note that attempting to perform a master reset or service complete without proper training or authorization can be dangerous and may cause damage to the equipment. It is always best to consult with an authorized technician or service center for assistance with these procedures.
IR IRN37 Compressor Fault Code 26
between the compressor's main control board and the user interface board. This can cause the compressor to trip with a USD (Unexpected Shutdown) fault.
To troubleshoot this issue, here are a few steps you can take:
- Check the communication cables between the main control board and the user interface board. Make sure they are securely connected and not damaged.
- Check the power supply to the user interface board. Make sure it is receiving the correct voltage and that the wiring is not damaged.
- Check the user interface board for any damage or loose components. If there are any damaged components, they will need to be replaced.
- If the issue persists, you may need to replace either the main control board or the user interface board.
It's important to note that working on compressors can be dangerous and should only be done by qualified technicians. If you're not familiar with the inner workings of the compressor or don't feel comfortable troubleshooting the issue yourself, it's best to contact a qualified technician or the manufacturer for assistance.
We have an Ingersoll Rand SDR25 Compressed Air dryer that won't shut
If your Ingersoll Rand SDR25 compressed air dryer is not shutting off when the air tank is full, there are a few possible causes:
- Faulty solenoid valve: The solenoid valve is responsible for controlling the flow of compressed air through the dryer. If the valve is faulty, it may not be closing properly, which could prevent the dryer from shutting off.
- Clogged or dirty inlet filter: If the inlet filter is clogged or dirty, it can restrict airflow through the dryer, which could prevent the solenoid valve from closing and the dryer from shutting off.
- Faulty pressure switch: The pressure switch is responsible for monitoring the pressure in the air tank and turning off the compressor when the tank is full. If the pressure switch is faulty, it may not be sending the signal to the dryer to shut off.
To troubleshoot this issue, you can try the following steps:
- Check the solenoid valve: Disconnect the air supply to the dryer and check the solenoid valve for proper operation. The valve should be closed when no power is applied, and should open when power is applied. If the valve is not operating properly, it may need to be replaced.
- Clean or replace the inlet filter: Check the inlet filter for any signs of clogging or dirt buildup. If the filter is dirty, clean or replace it and check if this resolves the issue.
- Check the pressure switch: Check the pressure switch for proper operation. You can use a multimeter to test the switch for continuity and check if it is sending the correct signal to the dryer to shut off.
If none of these steps resolve the issue, it is recommended to contact a qualified technician or the manufacturer for further assistance with troubleshooting and repairing the air dryer.
Ingersoll Rand SSR-EP100 over pressure faults
An overpressure fault on an Ingersoll Rand SSR-EP100 compressor indicates that the pressure in the system has exceeded the allowable limit, triggering the pressure switch to shut down the compressor to prevent damage. Here are some possible causes and troubleshooting steps to try:
- Check the pressure switch: Make sure the pressure switch is functioning properly and set to the correct pressure range for your system. If it's malfunctioning or set incorrectly, it may be tripping the compressor prematurely.
- Check the air filter: A dirty air filter can restrict airflow and cause the compressor to overheat, which can lead to an overpressure fault. Make sure the air filter is clean and replace it if necessary.
- Check the condenser coil: The condenser coil can become clogged with dirt and debris, reducing the system's ability to dissipate heat and causing the compressor to overheat. Clean the coil and remove any obstructions.
- Check for leaks: A leak in the system can cause the compressor to work harder than it should, leading to an overpressure fault. Check for leaks in the air lines, fittings, and valves, and repair any leaks you find.
- Check the unloaders: Make sure the compressor's unloaders are working properly. If they're not unloading the system when the pressure reaches the maximum level, it can cause an overpressure fault.
If none of these troubleshooting steps resolve the issue, it may be necessary to call a qualified technician to diagnose and repair the compressor.
VSD Fault G1F032VSD Fault INGERSOLL RAND 110 KW FAULT G1F032
The VSD Fault G1F032 on an Ingersoll Rand 110 kW VSD (variable speed drive) likely indicates an issue with the drive's DC bus. This fault code indicates that the DC bus voltage has dropped below the acceptable range, which can cause the drive to trip or shut down.
Here are some steps you can take to troubleshoot this fault:
- Check the incoming AC voltage to the drive to ensure that it is within the acceptable range. Low voltage or voltage fluctuations can cause the DC bus voltage to drop below the acceptable range.
- Inspect the DC bus capacitors for signs of damage or leakage. Damaged or faulty capacitors can cause the DC bus voltage to drop and trigger the fault code.
- Check the connections between the DC bus and the drive's power modules. Loose or faulty connections can cause voltage drops and trigger the fault code.
- Check the drive's cooling system, such as the fans or heat sinks, to ensure that they are operating correctly. Overheating can cause the DC bus voltage to drop and trigger the fault code.
- Consult the drive's manual or contact the manufacturer for additional troubleshooting steps or assistance.
It is important to take caution when working with electrical components and ensure that any modifications or repairs are done by a qualified technician.
Ingersoll rand irn-20tas-150-L a 68 error code (emergency stop) unit will not start. help please!
You have to twist the e-stop to reset it and once you’ve done this you still have to reset the fault by pressing the reset button on the controller. It looks like a red triangle inside a circle with a line through it and depending on how old your machine is, you may have to double-press the button. If this doesn’t fix it check the BLUE wires coming out of the estop going to the controller and make sure nothing is loose. If all this doesn’t fix it your estop button is probably broken.
