20 Most Recent Mtd LAWN MOWER PART # 787-01276-0637 DECK:21" PUSH Color POWDER BLACK Questions & Answers
Need a price on part # 687-02075a and 687-02074a
687-02075a $19.14
687-02074a $19.14
Ok, thats the prices.. Now do you want to know where to buy em??
www.mtdparts.com
7/19/2010 2:28:52 AM • Mtd LAWN MOWER... • Answered on Jul 19, 2010
WHAT YEAR WAS THIS MTD GOLD MADE...S/N 1C120B30159
Usually, the date of manufacturing and similar information is located on the same sticker. If you can't see/find this or locate your user manual, you should try calling their technical help line so they can search your serial# in their database: 1-800-668-1238
4/9/2024 6:07:33 PM • Mtd Garden • Answered on Apr 09, 2024
2answers
Tecumseh Enduro OHV XL/C 17.5 HP. Where is the drain plug on a Tecumseh Enduro OHV XL/C 17.5 HP Overhead Valve, single cylinder engine for a MTD riding mower.
Question edited for clarity and toss in some CAPS. It is side mounted.
OPERATOR'S MANUAL TECUMSEH
MTD Parts http://manuals.mtdproducts.com > manuals PDF Remove oil drain plug and oil fill plug to drain oil. E. Install oil drain plug and tighten securely. F. Fill oil sump with recommended oil. See "OIL & FUEL. 8 pages https://www.google.com/search?q=tecumseh+enduro+XL%2Fc+17.5+drain+oil ..
3/16/2024 9:37:29 AM • Mtd Garden • Answered on Mar 16, 2024
Rover Heavy duty 25 walk behind Slasher Mower. I am looking for the Parts manual please.
Question edited for clarity. Question moved to mowers. Scribd says it has a parts list, plus there is a link to the maker. https://www.google.com/search?q=Rover+Heavy+duty+25+walk+behind+slasher
Catalogue 2022 - Rover
rover.com.au https://www.rover.com.au > attachments > files PDF Heavy-duty, full length, fully-welded tubular steel frame is designed to absorb impact and provide maximum stability. LB. CHOICE OF. LAP BARS. OR STEERING. ..
2/18/2024 8:32:52 PM • Mtd Garden • Answered on Feb 18, 2024
Yard machine tiller model 137202
Yes
2/10/2024 3:32:29 AM • Mtd Garden • Answered on Feb 10, 2024
2answers
MTD 618-04907A Transmission stuck in reverse
Here are a few things you can check to troubleshoot why your TroyBilt riding mower is stuck in reverse:
  1. Check the transmission fluid level. The transmission fluid level should be between the "full" and "add" marks on the dipstick. If the fluid level is low, add the specified type and amount of fluid.
  2. Check the transmission fluid for leaks. If the transmission fluid is leaking, it could be causing the transmission to slip. Repair any leaks and refill the transmission fluid.
  3. Inspect the transmission linkage. The transmission linkage is a series of cables and rods that connect the transmission lever to the transmission. If the linkage is damaged or misadjusted, it could be causing the transmission to stick in reverse. Inspect the linkage for damage and make sure it is properly adjusted.
  4. Inspect the transmission gears. The transmission gears are responsible for transferring power from the engine to the wheels. If the transmission gears are damaged, it could cause the transmission to stick in reverse. Inspect the transmission gears for damage and replace any damaged gears.
If you have checked all of these things and the mower is still stuck in reverse, you may need to take it to a qualified mechanic for further diagnosis and repair. Here are some additional tips for troubleshooting transmission problems:
  • When diagnosing a transmission problem, it is important to check the fluid level and for leaks first. Low fluid levels or leaks can cause the transmission to slip, which can lead to other problems.
  • If the fluid level and for leaks are okay, then you can start inspecting the transmission linkage and gears. The linkage should be properly adjusted and the gears should not be damaged.
  • If you find that the linkage or gears are damaged, then you will need to replace them. You can also try adjusting the linkage if it is not properly adjusted.
  • If you have checked all of the above and the mower is still stuck in reverse, then you may need to take it to a qualified mechanic for further diagnosis and repair.
8/26/2023 9:51:26 PM • Mtd Garden • Answered on Aug 26, 2023
Need Model Number for 2013 MTD / Briggs & Stratton Lawn Mower
Suggest you try MTD phone support.
855-971-2271
8/7/2023 9:42:59 AM • Mtd Garden • Answered on Aug 07, 2023
2answers
Does an MTD model 21AA414A729 use gear oil ?
No, it uses a mineral oil/clay grease.
Owners manual is avaiable for download, no fee.
https://www.mtdparts.com/en_US/prior-year-models/yard-machines-garden-tiller-model-21aa414a729/21AA414A729.html
The transmission is pre-lubricated and sealed at the factory. It requires no checking unless the transmission is disassembled. To fill with grease, lay the right half of the transmission on its side, add 22 ounces of Benalene 920 grease, and assemble the left half to it. This grease can be obtained at your nearest authorized dealer by ordering part number 737-0300.
5/13/2023 11:43:44 PM • Mtd Garden • Answered on May 13, 2023
Where do I find the drain plug on a MTD Yard Machine for transmission that's not hydraulic
no info generic answer on most remove rear cover panel to access trans axle or axle --for mid size plug lower section under linkage --small ones no service port ------on larger with a transmission plug on side
11/17/2022 4:12:29 PM • Mtd Garden • Answered on Nov 17, 2022
I have an MTD husky 18-in rear tine tiller, my times turn backwards, but I have no forward or reverse in the transmission
There should be 5 positions for the gear selector.
Neutral
Reverse
Forward 1 wheels only
Forward 2 wheels and tines reverse rotation
Forward 3 wheels and tines forward rotation
If you have reverse tines only, then the problem is internal to the transmission. My guess is the wheel drive chain.
11/6/2022 2:08:11 PM • Mtd Garden • Answered on Nov 06, 2022
Mtd yard machine forward issue
Hi, it sounds like someone has switched the gears of operation in your device. You would need to call 1-800-269-6215 to reach MT yard to send someone out to fix it . Otherwise, you could have a major accident. Thank you.
10/5/2022 7:16:59 PM • Mtd Garden • Answered on Oct 05, 2022
2answers
Free service manual for a MTD Power pro Lawn tractor model LT4218A serial @: 032194A - 004925
You'll get it for FREE soon !!!!! Wait.
9/28/2022 8:08:39 PM • Mtd Garden • Answered on Sep 28, 2022
How to change the steering shaft in Huskee riding mower
I used a number 3 Phillips impact bit and drill
9/19/2022 8:12:18 PM • Mtd Garden • Answered on Sep 19, 2022
I replaced the deck belt on my yard machine riding mower that it calls for but it's too long and there doesn't seem to be an adjustment, what can I do?
First I would double check that its routed correctly. If you still have the old belt, compare it to the size of the new one.
8/10/2022 10:43:13 PM • Mtd Garden • Answered on Aug 10, 2022
Belt diagram for mtd 92 13H2765E600
Should be able to find the manual on line, giving the diagram for the belt positioning.
7/17/2022 4:44:13 PM • Mtd Garden • Answered on Jul 17, 2022
B&S 17.5hp model 313707 type 0162-E5 code 020311ZE there's a yellow wire that's not hook up
basic diagnostics do not include parts list. is there fuel in the tank? is the fuel getting to the carburater? pull the plug, is fuel in the cyliner? wet plug? Does the engine turn over when ignition key is turned? is there a spark when the engine turns over. are all controls set correctly? driver in seat safety switch working transmission in neutral, blades disengaged. throttle set to start. parking brake on?
7/10/2022 9:54:07 PM • Mtd Garden • Answered on Jul 10, 2022
Looking for a wiring diagram for MTD 1740h mower. Thanks
https://www.smarts4k.com/wiring-diagram-mtd-mower/ See if this is what you are looking for.
6/3/2022 1:53:18 AM • Mtd Garden • Answered on Jun 03, 2022
2answers
Need to change drive belt need service manual
If you go the internet and find your tractor you will find that manual on line. I had the same problem with the same type on tractor
5/22/2022 3:20:39 PM • Mtd Garden • Answered on May 22, 2022
Mtd LAWN MOWER PART # 787-01276-0637 DECK:21" PUSH Color POWDER BLACK Logo
Popular Tags
1 questions posted
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
View Most Popular
Mtd Garden
  • Mtd Garden
Most Popular Question
need price part 687 02075a 687 02074a
  • Garden
