20 Most Recent
RTO Mow Aerator Riding Lawn Mower Tire Brackets Questions & Answers
Right front tire of riding lawn mower is bent in,
As long as teh bead selas and the tire holds air, i'd leave it. Othewise, go to northern tool and equipment or fleetfarm and find a replacment rim. there all pretty standard widths and bolt patterns. Should be too expensive either.
Stops running after warms up
It's eithe your coil ha heat soak and needs replacing or your fuel circuit isn't venting properly and is creating a negative pressure
11/22/2013 10:43:17 AM •
RTO Garden
Answered
on Nov 22, 2013
Rotohoe tiller won't start any ideas?
First step is to check for spark. Remove the spark plug. You can put the plug wire back on. Then pull cord. Should have a blue spark at the plug. If you do. Try putting a small amount of fuel table spoon in plug hole. install the spark plug and see if it will start. If it dose and will not run for more then a few seconds your not getting fuel. Make sure the fuel is on and clean. If this dose not help you need to make sure the carburetor is getting fuel. Turn off or pinch fuel line. remove from the carburetor . turn back on fuel see if flowing. If this is ok and still wont run. The float in carburetor is stuck. Remove float bowel. Bolt on bottom. Lightly tap with fuel on and see if flowing. If not turn fuel off. Remove float bowel. Under the float is the needle and seat. remove the needle turn on fuel see if flowing. should be. Replace the needle if tip is bad. if not reinstall and install float bowel. prime by first step small amount of fuel in spark plug hole. Should be fine after this.
5/21/2010 6:30:35 AM •
RTO Garden
Answered
on May 21, 2010
