20 Most Recent Briggs 3500W Port Generator Questions & Answers
Have a problem with a 5 horse Briggs only can make it turn half ways then locks up
Take the spark plugs out and try again. There are several reaons this could happen. Then remove starter motor and try again make sure starter motor is free to runInternal engine damageDamaged starter motorExcessive carbon in the cylinder heads (common)
11/17/2013 2:40:59 PM • Briggs 3500W... • Answered on Nov 17, 2013
I have a husky 3750
The fuel filter is probably partially clogged or the adjustment screw for the fuel mixture on the carb has backed off due to vibration. Try turning in the screw in 1/8 th of a turn at a time every time you start it.
Screws always loosen due to vibration so you only have to adjust in to fix it.
Regards
TickMagnet
8/15/2011 1:29:50 PM • Briggs 3500W... • Answered on Aug 15, 2011
Looking for service manuals. must
http://www.m-and-d.com/pdfs/GEN_ENG/GN190-220.pdf
here is a link to the service / parts manual
joe
1/22/2011 12:24:11 AM • Briggs 3500W... • Answered on Jan 22, 2011
Pull cord stuck on Briggs & straton generator
Had this happen to me. The problem turned out to be a mouse nest inside the gaps around the flywheel(?) assembly that is behind the starter pull cord. I pulled off the starter and saw some mouse crud. I cleared that out and reassembled. Pulled the cord again and heard clunk, snap, and breaking pieces bouncing around. Everything was stuck again. Disassembled again to see some of the plastic blades of the fan snapped and there was a lot more mouse nest jammed in. Spent 2 hours digging out what must have been at least a basketball sized cloud of mouse nest. I had to dig, spin a little by hand, keep digging. Eventually I got it all out and the engine fired up nicely. It seems this design a a lot of wide open spaces that suit mice nicely. Combine that with years of storage with no use and you get an epic mouse nest.
11/8/2021 12:55:55 PM • Briggs... • Answered on Nov 08, 2021
I have a Briggs and stratton elite series 5500 generator. Runs great. No smoke. No unusual noise. Oil is spraying out the exhaust. What is wrong?
Oil level is too high and thin from fuel. Check for stuck carburetor float or debris in fuel bowl or inlet needle.
It may also happen if the unit was moved and tipped at a severe angle.
10/19/2020 2:09:53 AM • Briggs... • Answered on Oct 19, 2020
My 5000 watt PowerBack Briggs & Straton generator starts right up, but then shuts off after about 5 minutes. What's the suggested remedy for this issue, please?
Try disconnection oil level sensor. If problem goes away, replace sensor.
3/4/2020 1:27:27 PM • Briggs... • Answered on Mar 04, 2020
The Briggs & Straton o40305 generator turns on does not turn off the starter and does not generate AC voltage
25kva-3125kva Diesel generator set: www.dieselgeneratortech.com
1/15/2020 5:36:40 AM • Briggs... • Answered on Jan 15, 2020
2answers
What are the valve settings on my generator 5250 Porter-Cable 10 horsepower Briggs
If you need to have a new diesel generator set, please visit at the good website, the quality is very good, so i recommend it to you. This is the website: https://www.dieselgeneratortech.com/diesel-generator
9/9/2019 6:45:17 AM • Briggs... • Answered on Sep 09, 2019
Briggs and Stratton 5500 generator coil won’t pull out
Armature coil needs to be coaxed out, slight tap on the metal base with a screwdriver should take care of this.
7/10/2019 12:40:17 AM • Briggs... • Answered on Jul 10, 2019
My Briggs and Stratton 7500 watt generator no power I jump the brushes with 3 12 v batteries in series making 36 v and I get power does this mean I have a bad avr or something else
Most generators are self energising. Residual magnetism in the armature causes a small output as soon as the alternator is turning at speed and circuitry feeds the small output through the brushgear into the armature to begin the energising cycle until the rated output is reached. As you obtain an output from the stator by "artificially" energising the armature, it is clear there is a fault in the control circuitry. There are wiring diagrams online but they aren't easy to follow...
5/4/2019 1:42:44 AM • Briggs... • Answered on May 04, 2019
Briggs and Strattion portable generator model 030324-0, 5550 watts. Has 220 but no 110 power.
There are reset breakers on the control panel. If the 110 outlets are GFI protected then the issue could be your cord or appliance. Please try some other type of item (Tool or lamp). If the breaker was over whelmed and tripped the breaker. The breaker is labeled and mounted on the control panel as well. Please write back if there is anything else.
10/6/2018 6:08:57 PM • Briggs... • Answered on Oct 06, 2018
Briggs and stratton generator avr how to text
Briggs and stratton generator avr how to text. "Text"??
5/22/2018 8:24:40 PM • Briggs... • Answered on May 22, 2018
Briggs and Stratton generator will spark but no start
Then you need fuel! Make sure the gas is turned on. Pull the sparkplug after a few tries and see if it's wet with fuel or smells like it. Thats all a motor needs is spark and fuel! Well air too.
10/25/2017 12:53:46 AM • Briggs... • Answered on Oct 25, 2017
Briggs Stratton model 030235 5500W portable generator. Notices oil leak underneath. What are possible causes? Could it result from tipping?
Possible but not likely. Wipe off the excessive oil and try to ascertain where it is leaking. Possibly loose hardware needs tightening or a gasket replaced. Could also be a crankshaft seal.
9/23/2017 2:20:14 AM • Briggs... • Answered on Sep 23, 2017
2answers
I recently rebuilt nikki carb on briggs and Stratton storm responder and when I put carburetor back on it spews gas out of carb when I turn fuel on?
He Harry, its never fun when you work on something and its worse than when you started.. Take it to a qualified professional..
7/8/2017 9:51:38 PM • Briggs... • Answered on Jul 08, 2017
2answers
I have a storm responder generator briggs and Stratton 5500 drained all of the old fuel and cleaned spark plug generator wont start what could be the problem
tankfilter not sludged tank fuel tap filter working clean it fuel hoses good ?(allways first take airfilter off in case of test temporarily) clean it with some fuel if its need will sometimes help) carburetor float chamber the sprinkler . in most cases the OILLEVEL can be to low level it to the right position The oil level must be against the screw of the dipstick if nothing helped disconnect the Oil surveillance but only Temporarily try it look the sparkplug for a good blue colored spark is the compression good the valves also old fuel isnt not allways a problem only when compression is bad because of Octane number
6/24/2017 11:29:22 AM • Briggs... • Answered on Jun 24, 2017
Briggs 3500W Port Generator Logo
Popular Tags
6 questions posted
Top Briggs Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs Electrical Supplies
Most Popular Question
problem 5 horse briggs only make turn
  • Electrical Supplies
