Home | DeLonghi | Air Conditioners
DeLonghi Pinguino PAC-700T Air Conditioner
Problems with DeLonghi Pinguino PAC-700T Air Conditioner?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
DeLonghi Pinguino PAC-700T Air...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for DeLonghi Pinguino PAC-700T Air Conditioner RSS Feed
View More Results for DeLonghi Pinguino PAC-700T Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for DeLonghi Pinguino PAC-700T Air Conditioner RSS Feed
Answer
I emptied water valve at bottom which I shouldnt have to do until end of season...still water... (More)
Answer
is there something I should be doing........I don't have the manual so where can I get one...thanks
Answer
Delonghi - Pinguino PAC 70 AC isn't exhausting any hot air through the back - then shuts down after... (More)
Answer
FixYa: Is there a known problem with these particular Penguina units making a terrible intermittent... (More)
Answer
Hi, I have the DeLonghi Pinguino PAC-700T Air conditioning (portable unit), the unit was functioning... (More)
Find a Manual
DeLonghi Pinguino PAC-700T Air Conditioner Manuals & Guides
Tips & Tricks
(Post a New Tip)
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
COMPRESSOR check outs semplified.
If your wondering how to check out your refrigeration compressor; Modern Compressors have two operations that have to work together just to run.... written by farfield
Air Filter changing - easey and often
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date... written by farfield
AC DRAINAGE PIPING REQUIREMENT
Slide 71 .O {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC... written by bobotfel
HOW TO CHECK A GOOD REMOTE CONTROL
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and... written by bobotfel
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Pinguino PAC-700T Air Conditioner
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Find an Expert
Meet our 2636 Air Conditioner Experts
dmftrucker
Rank: GuruGuru
Rating:  87%, 404 votes
Solutions:  1582 (476 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
projdoc
#2: projdoc
Rank: GuruGuru
Rating:  94%, 600 votes
Solutions:  1178 (451 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
roniecon
#3: roniecon
Rank: GuruGuru
Rating:  88%, 642 votes
Solutions:  2146 (385 Votes in the last 30 days)
Experience: A S E certified /35 years experience
justaskjoe
Rank: GuruGuru
Rating:  85%, 1989 votes
Solutions:  3842 (356 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
57 varieties
Rank: GuruGuru
Rating:  88%, 515 votes
Solutions:  1495 (333 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
localwonder
Rank: GuruGuru
Rating:  92%, 2774 votes
Solutions:  4901 (319 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
avid101
#7: avid101 Expert Moderator
Rank: GuruGuru
Rating:  87%, 1143 votes
Solutions:  2442 (312 Votes in the last 30 days)
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
techbuster
Rank: GuruGuru
Rating:  89%, 492 votes
Solutions:  1107 (271 Votes in the last 30 days)
tbirdfan1
#9: tbirdfan1
Rank: GuruGuru
Rating:  85%, 668 votes
Solutions:  1495 (217 Votes in the last 30 days)
Experience: 19 years computer build\repair and troubleshooting tech support, certs including comptias a+ Acore
buffalonyman
Rank: GuruGuru
Rating:  85%, 712 votes
Solutions:  1818 (207 Votes in the last 30 days)
Experience: Licensed Master Electrician for 25 years, Plumbing, HVAC, Custom Build Computers, Automotive
Find a Warranty
Specifications for DeLonghi Pinguino PAC-700T Air Conditioner
Other Features
Moisture Removal (Pt/h)
2.11
Filter
Reusable
Air Flow
217.77 CFM
Cooling Operating Range
70 - 90
Key Features
Type
Stand Alone/Portable
Remote Control
Without Remote Control
Dehumidifier
With Dehumidifier Functionality
Cooling Capacity
12000 BTU/hr
Energy Efficiency Rating
13.3 EER
Fan Speeds (Cooling)
Electrical Requirements
Voltage
115
Cooling Ampacity
7.8
Cooling Watts
900
Dimensions
Depth
17.13 in.
Height
30.41 in.
Width
22.33 in.
Warranty
Warranty
1 Year
DeLonghi Contact Information
Main support number1 800 322 3848
Email supportcustomerservice@delonghiusa.info
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
