20 Most Recent
Black & Decker Workmate® Swivel Pegs Part No. 79 010 4 Questions & Answers
I have a BDS 300 sensor and have lost instructions
I just bought one too and instructions need deciphering. Select wood or metal with selector switch. Put unit flat against wall. Press and hold on/off button on left. (It looks like it must be kept pressed in at all times to be 'on' and when released it's 'off). The unit with calibrate and give a beep back and lower red LED will stay on. Move unit slowly left/right and more red LEDs light up until green is on. This is 1st edge. Mark it with pencil. Move unit along until Green is off and down to single LED. Then move it back in opp. direction until Green is on again. This is 2nd edge. Attached is a scan of page from Instruction Manual. Quality is lowish as attachment limit here is 150kb.
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
