20 Most Recent
RTO Lifespan Fitness Tr 2000 Hrc Treadmill Questions & Answers
Will not power on
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
We just bought a gently
From the manual: Troubleshooting
Symptom: The walking belt slows when walked on
a. If an extension cord is needed, use only a 14-gauge general purpose cord of five feet or less in length.
b. If the walking belt is over-tightened, the treadmill performance may decrease and the walking belt may be permanently damaged. Remove the safety key and UNPLUG the power cord. Using the 3/16" allen wrench, turn both rear roller adjustment bolts counterclockwise. 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each side of the walking belt 3-4 inches off the walking platform. The center of the walking belt should just touch the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert safety key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
c. If problem persists, contact customer service.
I need to download a operating manual for a roger
Dear Sir:
I hope everything is o.k. Try with this lind for to download, you must paid for the manual.
http://www.fitnessrepairparts.com/
Thank you in advance, and if you need some reach me. Try again.
Blessing.
E.Cuadra
Managua, Nicaragua. C.A.
I have a LifeStyler Expanse 1500 treadmill. It
You may have a belt and deck problem. Test by the following procedure:
without the power on stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction I first apply silicone lubricant and see if that clear up the problem. Most problems originate from the belt and deck 75 to 85% of the time.
On occasion, you may have already damaged the DC board if you have high belt/deck friction. If the belt walks freely, you have a different problem.
